cooling fan wiring??
Old Aug 29, 2010 | 11:36 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i recently bought a 91 camaro rs V6
the motor fan was being powered off the blower motor connector. i went ahead and changed that and put the connector back to the motor. found the black and red wire off the cooling fan relay, found continuity and reconnected those 2 wires but fan still not working. there is a swite i belive off the radiator, im wondering if that needs to be connected to what and where? if anyone has a diagram or tell me how excalty that fan should be hooked up that would be great
Old Aug 30, 2010 | 02:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Kool Rool
There’s no switch off the radiator on that car.
With the key in the RUN position, ground the green/white wire on pin F at the fan relay.
Does the fan run?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Sep 6, 2010 | 06:40 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: The Kool Rool
i grounded them together and nothing? but heres some pics. thats the connection on the radiator. and the other one is where the wire was cut and then connected to that port on the blower motor to get power.http://i21.photobucket.com/albums/b3.../Image3581.jpg
http://i21.photobucket.com/albums/b3.../Image3571.jpg
Old Sep 6, 2010 | 06:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: The Kool Rool
'91 v6 fan is ECM controlled.
*edit.... looking closer, I'm not sure wtf that is. That's the return spout for the heater core with some kind of sensor shoved in it.
Proper wiring diagram attached.
Old Sep 6, 2010 | 06:55 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: The Kool Rool
oh thanks. that should help alot to track down the problem.
Old Sep 6, 2010 | 06:56 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: The Kool Rool
The relay should be located on a bracket, next to the brake booster
Old Sep 6, 2010 | 06:59 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: The Kool Rool
ya i found the relay. a few days ago when i was dealing with it. i dont think it was gettin power and i replaced all my fuses but ill have to deal with it later. i have a new problem im workin on with losing oil pressure so the oil pan is out right now
Old Sep 6, 2010 | 07:24 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: cooling fan wiring??
if it starts good and drops over 'x' time, the oil gauge sender may be the issue (unless replaced already).
Old Sep 6, 2010 | 07:29 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i thought it might be that. but once the gauge would get to zero the car would die. and start knocking. then after a few hours it would start up again and knock for about a second and then stop and the pressure was normal. when i pulled the pan though there was alot of stuff plugged up in the pick up screen and alot of crap in the pan. im hopin none of it is in the motor plugging things up
Old Sep 17, 2010 | 05:08 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i connected the hot (red wire) to the fan wire (red and black) at the connector and the fan ran. the relay is new. is it on a delay of some sort? i know D and F pin need to be enegized to close the fan switch. all my fuses have been checked and all are good now.
Old Sep 20, 2010 | 09:32 AM
NINÅ's Avatar
Transmission: 765R4
The Kool Rool
It’s not on a time delay, but it is turned on by the ECM VIA a temp sensor.
The ECM turns on the fan about 220°.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
