water pumping out of radiator
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I replaced my water pump this weekend. No leaks, Seems to work, but I run the car for a minute or two to see if the water and thermostat are working correctly. The water just rises and keeps rising until it bubbles out. It is not really hot so it isn't boiling.
Could it be my heater core? Is the pump working? All of the youtube videos that show how to do this run their cars w/o radiator cap. What is wrong? The pump and thermostat are brand new as are all belts and hoses. I did run the heater core hoses myself and wonder? could they be backward? does it matter?
Car: 1984 Z28 T-TOP
Re: water pumping out of radiator
I see mention of a bypass valve. It the valve neccesary? I have a 4bbl carb and never had one (since I bought it).
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There may be a chance you got the wrong rotation pump for your engine.
V-belt is standard rotation. Serpentine is reverse rotation. They look the same physically
The bypass is for the heater core.
Car: 1984 Z28 T-TOP
Do I need the bypass? Can I run the hoses strait to the heater core?
Car: 1991 RS Camaro
Engine: 400 Smallblock
Yes you can run the hoses straight to the heater core. The bypass valves purpose is simply to divert the coolant from the heater core and thus make the interior of the car a little bit cooler. It really makes very little difference anyway.
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Just asking, did you put the thermostat in upside down????
It seems that there is no circulation, but just a straight dump, as the coolant can't go anywhere's, but out the radiator!!!
It is after all a "water pump", and it will pump until it cavitates, and then it will stop, only after it pumps all the coolant out that it can!!
Also, once you fill the rad up, and before you start the car, move the defrost to the full heat, full defrost positions, and run the fan on high, then start the car!! Run the car until the thermostat opens up!! This will help to get any air pockets out of the system!!
Engine: TPI 305/ v6
He obviously has a blockage somewhere, and based on his post, I took the assumption that he changed his t-stat at the same time also, doesn't hurt to take a look to verify it!!
Engine: TPI 305/ v6
Engine: TPI 305/ v6
Maybe we're misunderstanding each other but, the SBC water pump either moves water (freely) or, it doesn't (blocked). It doesn't build water pressure. And I have no clue how, due to 'blockage, it could possible reverse flow (change direction).
But, to try a demean me as if I'm f'n clueless, I've been on these boards for over 10 years (yes, prior to 2000) and obviously, I own a few sbc cars.I do believe I have a grasp of how the t-stat and cooling system works for these cars.
So, prior to opening temp, all cars should puke because since the thermostat isn't open, the coolant is reverse flowing (changing direction)?
I was wondering how long it would take for you to use the "I've been on these boards for over" "x" number of years routine, didn't take too long, but as to trying to "demean" you as "f'n clueless", not intended at all, it's not my fault that you can't take a "wider" look at things, and start to use inappropriate language, when you don't get your way, or meet up with some opposition!!!
Too bad the OP of this thread doesn't come back with what the problem is/was!!
P.S. They do tell you to install thermostats in a particular direction also, I wonder why they do that????
Engine: TPI 305/ v6
Expand my horizon sage, I'm not against it.
Regardless of the OP, tech discussion is good banter.
I agree, tech discussion is good banter!!
Flogging a dead horse isn't!!
eightsixseven
Dec 16, 2024 01:50 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
