Massive amount of smoke billowed from engine bay.
Old Jan 20, 2011 | 12:05 AM
Nasphreak29's Avatar
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
I got off from work and decided to stop by Mickey D's on my way home, stopped at the Drive through...got through ordering my food, and massive amounts of white smoke started billowing from both sides of my engine bay.
My car was at a little above 220 at this point which is normal for when I am at a complete stand still, when I went to go pull around into a parking spot...I had not power steering at all. Popped the hood and there was radiator fluid EVERYWHERE. (or what I assumed at the time was power steering fluid).
Got my food, turned on my car and started on my way home, car started to get hotter and hotter and hotter till i finally got home...like 7minutes away pulled into my driveway turned off my car and a god awful amount of smoke was pouring out.
I have no idea where to even begin to looking, just looking for some ideas for when i get up in the morning, anybody?
Old Jan 20, 2011 | 12:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Massive amount of smoke billowed from engine bay.
Should be easy enough to find a coolant leak that big.
Old Jan 20, 2011 | 01:30 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
same thing happen to me 2 summers ago. mine was a bad lower radiator hose. check all hoses. It my even be a shot radiator.
Old Jan 20, 2011 | 08:19 AM
icantdrive55's Avatar
Car: '89 RS vert
Engine: 305 TBI
Why would you continue driving your car for an additional 10 min knowing you were losing most/all of your coolant? You may be in for a whole lot more pain than merely some new hoses and/or radiator...
Good luck with your repairs. I hope you didn't ruin anything expensive.
Old Jan 20, 2011 | 05:53 PM
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
7 and 10 is a big difference but okay....and losing and LOST are two different things, I would have much rather make it home losing coolant than be stuck and have to change my radiator in a McD parking lot...just saying...
And it was my radiator, bought a new one replaced it, took me 45minutes and about 120$ and i was set to go.
Old Jan 20, 2011 | 07:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd rather change a radiator in a parking lot than a head gasket in my garage.
Old Jan 22, 2011 | 04:17 PM
Car: 91 formula
Infested
May 22, 2018 11:56 PM
Polo Z03
Sep 10, 2015 06:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
