stock 3-gen dual fans AMP @ CFM ?
Old Feb 16, 2011 | 06:27 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
What to stock thirdgen dual fans draw as far as amperage , and cfm rating with both running at same time .
Old Feb 16, 2011 | 07:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: stock 3-gen dual fans AMP @ CFM ?
i tested a set of those once,found each motor pulled 7.5
amps once up to full speed-so 15a total at 14v,startup
surge was about twice running current.
i do not know the CFM rating,but i'd recon around 1200-
1300 CFM each
Old Feb 17, 2011 | 10:47 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Not sure about OEM factory - but the replacements commonly sold (AZ/Advance) generally draw 11.5 amps (might be initial startup amperage draw rather than after startup) and about 1150 cfm each.
Old Feb 18, 2011 | 05:57 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Thanks guys the stock fans work well with my set up, just changing over to some nicer ones that will be similar in amp draw and cfm thanks .
RazorN8
Jan 7, 2022 11:44 AM
beastin91rs
Oct 9, 2015 07:38 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Dialed_In
Aug 20, 2015 01:45 PM
