Another ambiguously titled water pump thread
Subscribe
Mar 20, 2011 | 03:20 AM
Many agree that the factory water pump should be upgraded when swapping in a firebreathing 383 stroker.
"Better than stock" water pumps range from $40 to $200+ on Summit
Is there a particular one that the TGO community agrees is a good one to go with?
Reply 0
Mar 20, 2011 | 05:42 AM
Re: Another ambiguously titled water pump thread
i have an edelbrock victor series on my 434. they're a little pricey at $171 each but well worth it.
ern
Reply 0
Mar 20, 2011 | 09:27 AM
Quote: i have an edelbrock victor series on my 434. they're a little pricey at $171 each but well worth it.
ern
same one on my 408, its been really good to me, have had it for 7 years now on 2 different engines
Reply 0
Mar 20, 2011 | 10:16 AM
I'm curious here, so just asking ...
383 is a 350, bored/stroked/whatever right? So we're still dealing with the same block with same water passages etc. Why would it need anything different than my 350? Does the fact that the piston size changed, the stroke changed, whatever make a 383 run hotter than a 350? I mean I guess higher compression I could see making more heat, but again, it's still a 350 block. I have 10:1 compression in my 350, doesn't run any hotter than a 8:1 or 9:1 compression motor.
So, wouldn't a standard off-the-shelf parts store heavy duty pump suffice?
Reply 0
Mar 20, 2011 | 04:00 PM
Horsepower makes heat. Its just a fact of life. Anything that allows you to get more fuel into the engine is gonna make your cooling system work harder. Could be an increase in displacement (350-383), a larger cam, NOS, even a CAI lets you burn a little more fuel.
Thanks for the input guys.
Reply 0
Mar 20, 2011 | 04:24 PM
like the other guy said, horsepower makes heat, and my 408 makes more power than a 350 or 383 with the same internal parts. the 434 is a 400 block.
the victor series is also aluminum, so there is a good chunk of cheap weight reduction right there as well.
the OP lists a
so i would think a better pump is in order, despite what i think about that particular engine ever being what more people would consider
Quote:
firebreathing
Reply 0
Mar 20, 2011 | 04:32 PM
Hey, that term was just an effect of posting at 3am, and not wanting to go through and list off all the parts.
Even if its not quite
Quote:
firebreathing
it could still use a cooling system upgrade.
Reply 0
Mar 20, 2011 | 06:04 PM
yes it could, im not disagreeing with you on that
Reply 0
Subscribe
