1985 iroc fan not coming on
Old Mar 27, 2011 | 10:10 AM
derekwillis's Avatar
i have replaced the temp sender on the front of the manifold and replaced the relay next to the battery and still overheating. it is 5.0 tpi single fan set up. i have read for hours on all the posts great stuff but i need individual attention. HELP i dont want to bring it to a mechanic.
Old Mar 27, 2011 | 11:47 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 1985 iroc fan not coming on
Have you made sure the fan even works with straight +12v ?
It (the fan) should run if you unplug the switch on your (pass side frame rail) A/C line or, if you jump the A-B terms on the ALDL plug.
The circuit is fairly simple...
Old Mar 27, 2011 | 11:51 AM
yes the fan does work.
Old Mar 27, 2011 | 11:59 AM
deadbird's Avatar
Engine: TPI 305/ v6
Test the tan/white for +12v Key on. If good,
backprobe the green/white wire and ground, key on.
The relay should switch and fan should run.
Old Mar 27, 2011 | 12:01 PM
in the attatchment the always hot wire does that come right off of the battery?
Old Mar 27, 2011 | 12:25 PM
deadbird's Avatar
Engine: TPI 305/ v6
I believe it should be on a fusible link, on the battery lug, at the starter.
Old Mar 27, 2011 | 12:33 PM
i have a wire about 10 or 12 guage that comes right from the battery that has been cut or worn open. also does the Air conditioning harness connected up by passenger side fire wall need to be connected? previous owner has that harness disconnected
Old Mar 27, 2011 | 12:40 PM
deadbird's Avatar
Engine: TPI 305/ v6
The main battery cable should have had a wire like that going to the lug on the back of the alternator.
The switch with the blue/blk wire on it is what sends the A/C request. The other wiring is for the compressor clutch.
When you unplug the blue/blk switch, the circuit is now open (normally closed) and the ECM should ground the fan relay (key on).
Old Mar 27, 2011 | 01:39 PM
there was a smaller wire other then the one that goes to the alternator. connecting the wire through seems to have fixed it. i have always wondered about that wire i just hate connecting wires that look like they have burned open....stay tuned .
Fronzizzle
Aug 17, 2015 02:52 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
