Which cars had factory dual fans?
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I own a 1991 Camaro Z28 LB9 305 (non-HO) with AC and was wondering if dual fans are factory. I have dual fan but the second fan (pass. side) seems to be just spliced into the power wires to the primary fan. Seems hacked.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Which cars had factory dual fans?
from what i have seen,all TPI cars with a/c got the dual
fans starting in 1987.
Car: 1992 RS
Engine: Carbed 350
(from what I can tell/read) ....
All dual fan cars were factory TPI cars. BUT - not all factory TPI cars had dual fans.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, I've seen lots of 5.0 TPIs with single fans. No idea why it was one way or the other though??
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
only the 85-86 (first years) TPI would have had single fan. 87 was a bastard/crossover year for the dual fan (wiring) and then from there, any TPI had duals, AFIK, not 100% fact.
I have to go through the wiring and see what this guy did and why. I assume if he jumpered the 2nd fan there may have been an issue of the car overheating in the past. Root issue may be a relay, sensor, etc. Found meself a bit of work to make it right.
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Im guessing you have a bad temp switch under the pass side head. It doesn't come on until 238 degrees, so it's also possible the prev owner thought it didn't work since he never saw it on.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
My 1988 Camaro Iroc 305cid came with a single fan without A/C and my 1989 Firebird TA 305cid came with dual fans with A/C.
Engine: TPI 305/ v6
My 88 LB9 H.O 5 speed is a single fan (non AC car) so even the HO was a single fan if it had no ac. All my others are 5.7 L98s and have dual fans.
Engine: TPI 305/ v6
I guess the OP led me to falsely believe we were taking about standard off the lot cars and not special order a/c delete and 1le cars... stupid me. I didn't clarify I was talking about standard cars as well. Sorry.
Engine: 383 Carb
Transmission: 4L60
never mind
I cant find a replacement fan temp switch at 230deg like stock. closest is a 200on/185off at Summit. My engine is completely stock including thermostat. Is this range okay?
ie: thermostat is 195 so if the temp switch was waiting for 185 to turn off it may never see it since flow cuts out at 195. I do have the thermostat out right now, maybe get a 180 to match the switch.
Car: '82 z28
Engine: L83 5.7
with electric fans,best to have then come on about
10-15*above thermostat temperature so they will be
off under most conditions when the car is in motion
instead of being on all the time wearing down the
motor brushes and pulling current.
If i had a third with dual fans,i would be really tempted
to wire the two fans in parallel(with seperate fuse for
each so if one fan is jammed or shorts out the other
will still operate)and use an aftermarket varible speed
fan controller.
fan controller.
colton_carlson
Mar 8, 2019 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
