overflow jug
Old Apr 9, 2011 | 06:28 PM
Jaws031's Avatar
Car: 88 camaro
overflow jug
is the overflow jug has a hole in it will the car run hot
Old Apr 9, 2011 | 07:42 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: overflow jug
depends on where the hole is. if it is near the bottom then it will leak coolant. and when the coolant expands when hot it will leak out. and when the radiator needs it back it will not be there. will take a while but yes eventually will unless you stay on top of it.
Old Apr 9, 2011 | 07:45 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: overflow jug
water/coolant is like air , it expands when its hot . it goes into overflow tank , when eng. & radiator cools it is drawn back into radiator . if it is not drawn back in , yes it will overheat . i suspect you may have other problems . a little more info. maybe i/we can help you more . good luck .
Old Apr 9, 2011 | 07:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: overflow jug
the cap on the overflow is open/vented, and needs to be, so there is already a hole there. without a vented overflow, the cooling system will build and not be able to relieve pressure. It will pushout waterpump gaskets and freeze plugs. I went through this a year or so back
you have other issues
Old Apr 9, 2011 | 08:56 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: overflow jug
http://cgi.ebay.com/ebaymotors/82-88...item3f08cdb8b5
thankfully, it's a cheap fix.
Old Apr 9, 2011 | 09:21 PM
Jaws031's Avatar
Car: 88 camaro
Re: overflow jug
i was just asking i was leaning on the overflow jug to tie down a bolt, and i pressed down to hard on the jug i guess . An a hole size of a half dollar coin was on the top of the jug when i got up. Just wondering will the car run hot because of this
Old Apr 9, 2011 | 09:57 PM
Tobias05's Avatar
Re: overflow jug
nope, won't be a problem.
take a look, you will notice the overflow cap is vented.
Old Apr 9, 2011 | 10:34 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: overflow jug
I would not chance it. I would buy a new or used one. My over flow tank boils but never over flows. But with a hole in it I think you might have trouble.
Old Apr 10, 2011 | 12:03 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: overflow jug
If your overflow tank boils all the time, your car is running to hot...
1992 Trans Am
May 10, 2023 07:19 PM
Bohemian
Aug 15, 2017 05:11 PM
Strick1
Aug 27, 2015 08:57 PM
palric
Feb 27, 2002 04:40 PM
bluegrassz
Feb 6, 2002 08:48 AM
