Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
replaced the under hood heat shield
Old Feb 26, 2002 | 04:22 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I bought a new under hood heat shield for my Formula. The original was missing so I picked one up from GM -- $89 CDN. Looks pretty good and took about 5 minutes to install (3 if I would have got it right the first time).
I'll be replacing the rad overflow jug as well. It looks like crap from brown gunk stuck to the walls of the jug.
Does this mean my cooling system needs cleaning ? I changed the anti-freeze last summer (did not power flush) and when I inspect the rad the stuff still looks bright green. Thoughts ? Comments ?
RP.
Old Feb 26, 2002 | 06:56 PM
trigger GTA's Avatar
Car: 92 TA vert
how much dose the over flow cost? mine looks like crap too.
Old Feb 26, 2002 | 08:43 PM
nblanchard's Avatar
I don't think there is any way to get out of the gunk in the antifreeze container. There will always be somekind of corrosion in the system, and when it sits, it glues itself to the bottle.
I may think of getting a new thingy too
Old Feb 26, 2002 | 09:42 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Powerflushing tends to blow heater cores out. Guess how I found that out
Old Feb 27, 2002 | 12:07 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
I wouldn't waste my money to buy another coolant resevoir, unless it is beyond repair. I cleaned out my '82 bird with no problem.
Remove your resevoir and soak it in Simply Green. Depending on how bad it is, let it soak for about an hour or two, then use a garden hose at full pressure or even better, a pressure washer( just be gentle with it). If there is still crud left, get a baby bottle brush and scub it out. Check my pics if you want to see the results before and after.Sorry my pics are so big, still learning how to use my Photoshop.
Old Feb 27, 2002 | 12:40 AM
nblanchard's Avatar
decent results.... I will try that first then... i was talking about getting a new noise deadner like palric got.
Old Feb 27, 2002 | 12:54 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Took alot of elbow grease to get that engine compartment cleaned up, but it was worth it. I will have to do my T/A in the spring, or when it warms up. I also need a noise deadener. I don't have the original hood. The car had been in an accident at one time.
Oh well, atleast it has a good home now.
Old Feb 27, 2002 | 01:05 AM
nblanchard's Avatar
yeah.. i took a closer look at those pictures.. man you are wicked detailer... looks original in there. I notice in original cars... the engine bay isn't totally covered with pain, there is primer showing in some spots, like the lower strut towers... strange... I have to buff the engine bay with fine compund by hand dang overspray!!! Oh well.. thank *** the nody is straight as an arroy, cause if it wasn't.... it would look horrid, gotta love black!!
Old Feb 27, 2002 | 09:20 AM
palric's Avatar
$26 at Stedelbauer GM
Last I called it was $26 at Stedelbauer GM. A cheap thrill.
RP.
Old Feb 27, 2002 | 04:40 PM
Car: 92 TA vert
thanks i will pick one up tomorrow
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
