what is this part
Old Apr 14, 2011 | 10:42 PM
z28 350's Avatar
what is this part
https://www.thirdgen.org/forums/atta...1&d=1302838874
can any one tell me what this is and were i can get another one
Attached Thumbnails what is this part-2011-04-14-22.06.33.jpg   what is this part-2011-04-14-22.06.42.jpg   what is this part-2011-04-14-22.07.02.jpg
Old Apr 15, 2011 | 02:29 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: what is this part
What year/engine does your car have? About where did you remove it?
Looks like an EGR solenoid or something like that.
Old Apr 15, 2011 | 02:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Never seen it - as asked - what year, engine, induction system - and what part of the car did that part come from?
Old Apr 15, 2011 | 03:11 PM
z28 350's Avatar
91 z28 350
https://www.thirdgen.org/forums/atta...1&d=1302898101
and i took a black peace off that covers them
and i thought that was the problem but does anyone know were the fan switch is cant find it because when the key is in the on position the drivers side fan runs and that peace i unplugged worked the first time but now its doing it again i cant figure it out anyone know
Old Apr 15, 2011 | 03:31 PM
Thats part of your emissions equipment, and is attached to your diverter valve (http://www.autozone.com/autozone/par.../N-iwkdyZ9gsn8). That part is certainly not the cause of your cooling fan issue. Even if that entire assembly was missing there wouldn't be a problem, it seems like maybe the temp sensor that turns your fans on is defective.
I am sure someone else can chime in on that, though.
(Oh, dont worry about that price on the diverter valve, I have no idea why it is so high when that part is virtually useless)
Old Apr 15, 2011 | 03:39 PM
Car: 1992 RS
Engine: Carbed 350
You have dual fans right? If so ...
Primary fan is controlled by the ECM. The ECM gets it's temps readings from the coolant temp sensor which is on the intake next to the thermostat housing - has 2 wires one black one yellow. This tells the ECM the temps, and the ECM turns on the fans.
If your primary fan runs always, channces are someone rigged it that way rather than replacing that CTS.
The seconday fan is controlled by the A/C - if your A/C or defrost is selected, then it will run always - so make sure your A/C and/or defrost is OFF.
The secondary fan is also controlled by the fan switch, which is located in the pass side head between #6 and #8 spark plug. It has a single wire to it, and it has a funny mushroom shaped connector.
DO NOT get this confused with the Knock Sensor, which is also on pass side and also has a single wire with the same funny mushroom shape connector - the Knock Senor is lower in the BLOCK, not in the head.
The ECM is programmed to run the primary fan starting at 218 degrees.
The fan switch is programmed to run the secondary fan at 238 degrees.
Good Luck!
Old Apr 15, 2011 | 06:01 PM
z28 350's Avatar
thanks alot to both you guy i didnt think that part did anything when i first took it off it started thats why i was wondering what it was and i think the fan switch is bad because i changed the temp sensor all ready and the air is of if the fan switch is bad will the car not start but thanks for the help
Old Apr 15, 2011 | 10:35 PM
Car: 1992 RS
Engine: Carbed 350
fan swithc will not affect starting or running of the car. Bad relay might though - some fan re4lays are tied into the alternator wiring somehow - but I'm no expert on these systems..
Old Apr 15, 2011 | 10:44 PM
z28 350's Avatar
so i dont need to switch that out or do i
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
