heater hoses? where?
Old Jun 14, 2011 | 02:40 PM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
im trying to hook up my heater and my dad said this is part of it, so what hoses do i use??
Old Jun 14, 2011 | 02:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: heater hoses? where?
There are two fittings on the heater core, one is 5/8" and the other is 3/4".
Chances are 999 in 1000 that yours was disconnected and bypassed because it was leaking coolant into the interior.
Old Jun 14, 2011 | 03:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, that other hole to the right of the pipe sticking out is where the other pipe should be that has apparently rotted off. You've got to replace the heater core before you can do anything else
Old Jun 14, 2011 | 04:28 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
ok but my problem is which hoses do i connect to the pipes? i cant figure it out
Old Jun 14, 2011 | 05:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You can pick up a Chiltons or Haynes manual for your car for around $20. Not the greatest resource for information, but much better than nothing. Either one should have a diagram showing everything involved in your problem and how to fix. Anything you don't get after reading that stuff we can help you with
Old Jun 15, 2011 | 11:47 PM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
I've done a few cores, the tube on the right has a hose that comes out and elbows down into a metal pipe, where the one on the left is a simple long heater hose that goes into a valve by the a/c compressor depending on what year your car is. Autozone has the smaller hose that's correct for your car. not sure if the following link will work but try it ,good luck.
http://www.autozone.com/autozone/par.../N-ii7n6Z91sul
Old Jun 16, 2011 | 10:21 AM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
wow thanks that diagram helped alot
Old Jun 16, 2011 | 10:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's the two right there in your picture joined together.
Old Jun 16, 2011 | 11:24 AM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
how would i get the pipe on the right out it looks bent in
Old Jun 16, 2011 | 11:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You have to replace the core.
Old Jun 16, 2011 | 12:07 PM
Car: 1988 gta-
Engine: 383 tpi
Aper. Is right, start early in the morning if you plan on doing by yourself, Ive changed quite a few.
Old Jun 16, 2011 | 12:53 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
how would i get it out from the top dash pad?
Old Jun 16, 2011 | 12:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Do a search, it's been described probably a dozen times. You have to partially disassemble the dash.
Old Jun 16, 2011 | 05:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Here's an article from the technical articles section. Lots of good material in there you may want to look over. I've never done this, but some say you have to loosen and pull back some of the dash also. Anyways, like mentioned above do a search on this board for lots of helpful stuff and you can check this out too.
https://www.thirdgen.org/heatercore
Old Jun 16, 2011 | 10:45 PM
Car: 1988 gta-
Engine: 383 tpi
I've done quite a few, yes the dashpad must come off and then all the screws holding the dash as well, its not that bad, its just when you get into that tight space where the heater core is, it can be frustrating because you will get scraped,but thats the fun part of owning these cars, right?
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
