Reprogram computer temp. Is it possible?
Old Aug 11, 2011 | 08:14 AM
Mailbox Hunter's Avatar
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
I was thinking, the cooling fan starts up at 238 degrees (single fan). Granted I get all the supply's and proper software, could I get into the ECM and change the coolant temp sensor to turn the fan on at like 210-220 degrees? Or am I cursed to stick in the 230-240 range?
Any other suggestions (outside of aftermarket fans and switches and things) to have my fan kick on at a cooler temp?
Old Aug 11, 2011 | 08:55 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Reprogram computer temp. Is it possible?
You can purchase http://www.summitracing.com/parts/HYP-4026/,
install a switch on the ground on the Fan
and yes you can flash your prom... to what ever MPH start and or temp you desire
Old Aug 11, 2011 | 09:01 AM
Car: 89 Camaro RS
Engine: 350 TBI
Thats perfect! Wouldn't I just have to replace the coolant fan temperature sensor on the passenger side with that (ie not ground of the fan, just direct replacement.)
How bad would flashing the prom be? I can only imagine a little difficult.
Old Aug 11, 2011 | 09:03 AM
Car: 89 Camaro RS
Engine: 350 TBI
Also with that replacement sensor, would I have to change my thermostat to say a 170 or 160? I have a 180 in there now.
Old Aug 11, 2011 | 09:07 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.carnut.com/ramblin/_cool3.html
Old Aug 11, 2011 | 09:13 AM
88gta3508's Avatar
Engine: 231 / 383
I ran a 160 but 170 for you would be recommended
it's gonna cost you some money... you can get free editing software & bins...but are harder to use for beginners... C.A.T.S is simple you will need to purchase your bin If I were you I would purchase the Romulator.... many many options out there
you should move this to DIY tuning
Old Aug 11, 2011 | 09:59 AM
Car: 89 Camaro RS
Engine: 350 TBI
When I get really into tuning I will have to.
Right now I'm worried about the cooling fans coming on at a better time, so if I get a 170 thermo, and a 178 on/ 168 off sensor, I should be set to cool at a sooner time than 238 degrees? Am I understanding that right?
Old Aug 11, 2011 | 10:26 AM
Car: 89 Camaro RS
Engine: 350 TBI
Very interesting article BTW! with that read I want to find a coolant fan sensor thats on/off at 175-185 lol. Really though, a good read that was very helpful.
Old Aug 11, 2011 | 12:57 PM
88gta3508's Avatar
Engine: 231 / 383
correct lower stat..... the hypertech kit will change the fan startup temp
this is the safest, economical!!! way to turn the fans on @ a lower temp
Old Aug 11, 2011 | 01:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
bookmark it
Old Aug 11, 2011 | 01:58 PM
Car: 89 Camaro RS
Engine: 350 TBI
Thanks for the help!
InfernalVortex
Apr 20, 2021 11:31 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
