84 camaro radiator ?
Old Oct 8, 2011 | 11:38 AM
James76's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 2.8l v6 soon to be 350
Transmission: auto
What is the plastic piece above as indicated by the red arrow? I am running a stand alone cooling fan with the sensor in the head.
Old Oct 8, 2011 | 03:00 PM
ex-x-fire's Avatar
Re: 84 camaro radiator ?
Maybe for a low coolant sensor?
I don't know if I'd trust just that fan you got, its really limited on how much area it covers. It needs a shroud, so it can pull air though most of the core.I was running one of those, I blew a head gasket on my v6 camaro, cause the fan couldn't keep up on a hot day.
Old Oct 8, 2011 | 03:05 PM
James76's Avatar
Transmission: auto
its 2300cfm...it blows your hair back
Old Oct 8, 2011 | 04:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Doesn't matter how many CFM it is if it doesn't cover enough of the rad.
Old Oct 8, 2011 | 04:32 PM
ex-x-fire's Avatar
I see that summit or jegs has an aluiminum shroud for 90 bucks. Universal type.
Old Oct 8, 2011 | 08:11 PM
87camaroPOS's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
My car has a steel line that threads into the open that seems to be plugging up, not entirely sure what it does though. Some sort of trans cooler maybe? It looks like the line runs off in that direction but its too dark to see right now.
Old Oct 9, 2011 | 09:57 AM
James76's Avatar
Transmission: auto
It was bought for an 84 carb model.. the 2 red plugs are for the transmission lines. I can see that this white plug is open to the main core and it just snaps in place. Unknown if it is sealed as is...
Old Oct 9, 2011 | 09:59 AM
ex-x-fire's Avatar
It should be sealed up as is.
Old Oct 9, 2011 | 10:35 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Yes, the fan isn't cooling enough of the core to get sufficent cooling. The more coverage the better.
Old Oct 10, 2011 | 07:58 AM
jb1's Avatar
jb1
Not sure what the plug is for (that radiator is used on many apps), but it has 2 internal o-rings and it is open to the inside, but it isnt threaded so just leave that plug in it.
I just put one of those radiators with the same plug in my 86 TPI yesterday and it did not leak a drop...go for it
Old Oct 12, 2011 | 11:48 AM
James76's Avatar
Transmission: auto
Thanks for the replys. I ran my other 84 with just a clutch mechanical fan and no shroud through 2 summers and never had any cooling issues. This should pull quite a bit more air across the rad at idle than the clutch fan ever did.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
