Upgraded Blower Motor?
Old Oct 9, 2011 | 05:12 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
First I will be running a '02 dash and I am willing to modify the firewall as I will be doing this anyway, but I'm wondering if anyone knows an upgraded rat trap style fan that might put out a higher volume of air than the stocker unit. Yes, I've searched and the best I came up with is "replace with new". I did that and still want more volume. Especially with this new dash going in, any suggestions?
Old Oct 9, 2011 | 05:42 PM
87350IROC's Avatar
Car: 87' IROC
Re: Upgraded Blower Motor?
Two things that would be easy to try. I'm not sure what voltage the stock blower runs at, but if its less than 12V you can try to increase increasing the voltage. Also you can try running a direct large gauge power wire from the battery to the blower through a relay.
Old Oct 10, 2011 | 10:30 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I have always wondered that too. mine blows cold, but not "hard" enough for me
Old Oct 12, 2011 | 04:57 PM
Engine: 355
Sorry for the delay, dialysis takes a toll. Anyway, while that, I think, in theory should kick out more juice, wont it burn out the motor faster, if not within a few months? Im also NO expert in electrical, so if this sounds nutty let me know but I was thinking of trying to check the amperage on a stock unit, if that kind of thing is listed, and then just trying to find something higher. But will it provide more pressure just because it takes more juice? Also to clarify the reason im looking for more out of the motor is because in a convertible, whether you need heat or cold, it dissipates much more than a t top or hardtop. No matter how new your weatherstripping is it just seems to find its way out. Too many female complaints
Old Oct 12, 2011 | 07:49 PM
87350IROC's Avatar
Car: 87' IROC
It really depends on what voltage it is good for and what it is getting. If you are planning on replacing the blower anyway, why not try checking and maybe bumping up the voltage. If it brakes who cares, replace it. If it doesn't then you've saved time and money.
Old Oct 13, 2011 | 12:17 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You mean like the factory high speed blower relay ?
Old Jun 7, 2012 | 01:02 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I ordered the most expensive blower motor thru Rockauto, ACDelco part # 1580213, I have yet to install it.
In the meantime, my heater hoses were not connected to the heater core, so i took the heater core out (not needed in Phoenix, IMHO).
I have no scientific way of proving that the AC blows harder w/o the heater core in the way, but it sure does feel like it, should even blow harder with new blower.
BTW, I plugged the heater core holes with cork from the dash side.
RT
Old Mar 14, 2013 | 03:30 AM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
Did you ever get positive results from this swap or anything else?
Frozer!!!
Jan 19, 2024 04:55 PM
zayne0
Aug 24, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
