pulley to electric fan?
Old Oct 17, 2011 | 01:05 PM
eboula24's Avatar
Car: 1984 camaro z28
Transmission: 5 sp
i went ahead and bought an electric fan set up from someone on here from an 89 or 91 rs recently for my 84 z28..everytime i look up info on how to do the swap i end up reading about switching to a serpentine set up..is this something that i have to do to make this swap work? i dont know a whole lot but it doesnt make sense to me that this would be needed. if i had to make the fan with a manual switch i would do that but im hoping not. anyone got any more info on this? or at least point me in the right direction? thanks.
Old Oct 17, 2011 | 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: pulley to electric fan?
Not much to it, take off the mechanical fan, clutch and shroud, install the electric fan and shroud, and wire it up.
Old Oct 17, 2011 | 05:02 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
get on summit racing or even E-bay and search for electric fan kits. No need to do it with a manual switch, the kits are pretty cheap.
Old Oct 17, 2011 | 06:28 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you dont need a fan wiring kit unless you want to have adjustable fan control. all you need is a 4 wire spdt relay and a fan switch with on/off temps of your choice and a lil bit of wiring knowledge. fan switches range from $5 - $30, and the relay should be about $5
Old Oct 17, 2011 | 08:41 PM
eboula24's Avatar
Transmission: 5 sp
ok, good to know. i was hoping it was that simple.
Old Oct 17, 2011 | 08:50 PM
eboula24's Avatar
Transmission: 5 sp
i was looking at the hayden 3653 kit here thats only $23..even if i dont need all those parts its so cheap...is it worth getting?
http://www.summitracing.com/search/?...20switch&dds=1
and im sure i wont need less than 185 therm..just a pos 305 anyway
Old Oct 17, 2011 | 08:53 PM
travis401's Avatar
Car: 91 Camaro RS
its just a low buck adjustable fan control. it personal preferance as to if you want adjustable control or not and how much you want to spend for bell and whistles you can get with the higher dollar ones.
Old Oct 17, 2011 | 08:54 PM
travis401's Avatar
Car: 91 Camaro RS
and btw, thats just an adjustable on off switch, you still need a relay and you have to wire it in your self.
Old Oct 17, 2011 | 09:43 PM
eboula24's Avatar
Transmission: 5 sp
ok maybe ill just look for the individual parts then. thanks for the info.
Old Oct 18, 2011 | 08:32 AM
*84TA's Avatar
Car: 84 Trans Am
When I swapped to a single electric fan in my 84 TA I used this fan controller from autozone.
http://www.autozone.com/autozone/par...er=326161_0_0_
It has been trouble free from day 1. I originally used a stock fan switch wired with a relay. Problem is this that stock switch was to high of a temp. for my motor. After some searching, I found that for the price for the adjustable fan controller was the same price as a decent hypertech switch and I had complete control of my on and off temps.
Old Oct 18, 2011 | 10:00 AM
eboula24's Avatar
Transmission: 5 sp
was it part # 733647 by compressor works? the site had me pick a year make and model before it showed me one..i just picked an 89 5.0 fi..looks right but wondering if thats the one you had used
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
