Both fans run constantly.....
Old Oct 29, 2011 | 10:11 AM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
I just noticed that both my fans are running constantly. Datalogging is reporting a coolant temp of 240+, but the dash gauge is pretty much maxes out at about 160.
Seems like I may have an issue with my Coolant Sensor that feeds the ECM?
anyone know off hand where exactly that sensor is? 88 TPI Vin F Motor.
AC is not on btw. Its broken, the clutch doesnt engage at all anyway.
I did just update my ECM to an 89 BIN. But now that I think about it, I think the fans were going all the time pre update. I never notice them coming on and the sound has always been consistent once I started it. The car has been hard to start when cold. seems to me that if the ECM is getting a 200+ temp reading all the time, I'm probably not getting any cold start enrichment.
Old Oct 29, 2011 | 10:28 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Both fans run constantly.....
sensor should be on the intake under the t-stat. if the computer is sayin 240+ then that sensor is either dead or grounded out.
Old Oct 29, 2011 | 10:39 AM
travis401's Avatar
Car: 91 Camaro RS
from everything i can find on the 88 305 tpi, its only supposed to have 1 fan, is the dual fan set up original? the 350 got the dual fans. im basing all this on the autstin 3rd gen wiring diagrams
Old Oct 29, 2011 | 11:04 AM
Impaqt's Avatar
Certainly looks stock. I bought the car a couple months ago and found absolutely no signs anything was touched on the vehicle except for some sporadic routine maintenance. Just checked my service manual and I see a reference to a Secondary fan relay.. and "Primary cooling fan" but it doesnt seem to mention a second fan...
odd....
I did pull codes and got nothing. But I noticed that after checking codes, when I started the car up, the fans stayed idle for about 2 minutes before firing up.. No where near the 185 I have them set to come on at.
Old Oct 29, 2011 | 11:08 AM
travis401's Avatar
Car: 91 Camaro RS
the ecm runs the main fan on the dual fan set up, and the secondary fan is run off a second relay with a fan switch in the head.
Old Oct 29, 2011 | 11:09 AM
travis401's Avatar
Car: 91 Camaro RS
if the dual fans arent original, someone could have wired them both to the ecm, or both to a fan switch.
Old Oct 29, 2011 | 11:10 AM
travis401's Avatar
Car: 91 Camaro RS
what temp is the ecm seeing with the engine cold and not running?
Old Oct 29, 2011 | 11:15 AM
Impaqt's Avatar
I was seeing 240.8 on my TunerPro RT Datalog. I think I saw it go a bit higher after it ran a while, but the engine didnt seem to be anywhere near that. I was getting false TPS sensor reading in my log as well, so figured it was another bug... But now, I'm pretty sure the sensor is shot.
Old Oct 29, 2011 | 11:47 AM
travis401's Avatar
Car: 91 Camaro RS
easy to replace, and only like $5 at the local auto parts store. just be sure to tell them coolant temp sensor
Old Oct 29, 2011 | 01:48 PM
Impaqt's Avatar
Replaced, Fans still kicking on early... Did find a hack though. Seems someone jumped the Primary and secondary relays together with a piece of wire and some scotch locks...... looks like its the ECM trigger wire for the fans.. Green/White
Gonna get the logger back on after lunch.
Old Oct 29, 2011 | 02:14 PM
travis401's Avatar
Car: 91 Camaro RS
the secondary fan is run off a switch on the passanger side head, looks like the knock sensor. it should be on the ground side of the relay. possible the fan switch went out and the PO just wired it into the primary relay to kick both fans on. or the dual fan was added and rigged in.
Old Oct 29, 2011 | 03:43 PM
Impaqt's Avatar
Next time I'm in the engine I'll check that out.
thanks
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
