rounded off torx heads on water pump
Old Nov 18, 2011 | 05:05 AM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Hi guys I'm trying to replace my water pump every thing was going smoothly until I hit the last two torx heads both of them rounded off. I am trying to grind off the head of one torx head in the hopes that the water pump will slide out then worry about the rest of the bolt when I get the water pump off do you guys know if my plan will work and is there a better way for the second torx because I'm at a lost
Old Nov 18, 2011 | 07:21 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: rounded off torx heads on water pump
just grind off the heads and use some vice grips to get the rest of the bolt off when you pull the pump
Old Nov 18, 2011 | 11:28 AM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Thanks. I wasn't sure if the threads on the torx were also attached to the water pump or just the engine block it self.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
