rad/fan combo
Old Jan 27, 2012 | 08:14 AM
kreator33's Avatar
rad/fan combo
i want to buy that ebay,champion rad by reliable radiators,the 3 core aluminum,,,should i get the kit with the 2 fans and can i use my single stock fan?would it be enough? and if i use the 2 small fan from the kit,,should i build a shroud to cover the rad?
Old Feb 24, 2012 | 06:24 AM
kreator33's Avatar
Re: rad/fan combo
anyone?
Old Feb 24, 2012 | 06:44 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: rad/fan combo
What are you trying to cool? Stock motor? Gonna race? What kind of climate in your area?
Old Feb 24, 2012 | 06:46 AM
kreator33's Avatar
Re: rad/fan combo
a 355 ,afr heads, tpi big mouth intake,58 mm slp runners, about 400 hp more or less,,,probly less, no heater,no a/c , canadian summer, 20-25 degrees c at the most in a trans am wich doesnt breath much at the front
Old Feb 24, 2012 | 06:47 AM
kreator33's Avatar
Re: rad/fan combo
160 thermostat,chip calibrayed to open fan soon
Old Feb 24, 2012 | 07:52 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: rad/fan combo
The stock single fan will be more than adequate.
Old Feb 24, 2012 | 09:55 PM
kreator33's Avatar
Re: rad/fan combo
should i shround the fan or leave it open like that
Old Feb 24, 2012 | 09:59 PM
kreator33's Avatar
Re: rad/fan combo
i meant shroud
Old Feb 24, 2012 | 11:23 PM
91 1LE's Avatar
Car: '91 1LE
Re: rad/fan combo
My stock single fan without a shroud(stock) and a stock radiator keep my engine cool. And mine makes more power than you are estimating. And I live in Phoenix. All I used was a good water pump, 170* thermostat, and a fan switch that turned on the fan at 200* and off at 185*.
Old Feb 25, 2012 | 10:43 AM
kreator33's Avatar
Re: rad/fan combo
you mean ,keeping the stock rad too? ,that would save me a lot of $
Old Feb 25, 2012 | 10:53 AM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: rad/fan combo
kreator33, you might want to look at this post that has been running for some time now:
https://www.thirdgen.org/forums/cool...guys-want.html
Old Feb 25, 2012 | 10:59 AM
kreator33's Avatar
Re: rad/fan combo
yeah,ive ordered a few from them before for other cars,,they are well priced, but if i can keep a stock one instead,would even be cheaper,, i have some here that are like new
Old Feb 25, 2012 | 06:21 PM
91 1LE's Avatar
Car: '91 1LE
Re: rad/fan combo
Stock radiator in good condition is fine too for your application.
Old Feb 27, 2012 | 01:52 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: rad/fan combo
I have the 3 core aluminum radiator from Champion with their dual fan and shroud setup. I'm very pleased with the radiator. It does require some modification to set it, but nothing that hasn't been addressed before.
I'm not very keen with the fans though. I have my run with Painless Performance relays but they don't seem to spin very fast. With the dual fans and shroud the car won't run below 220 degrees, and that's with a 180 thermostat.
My timing isn't set perfect, so that may very well be the case for running very warm. Over all though, I highly recommend Champion's products.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
