TPI Throttle By Pass, Coolant every where
Old Feb 20, 2012 | 05:59 PM
tylerf's Avatar
not sure if this is the right place or not, but here it goes.
88 gta auto 305
I need to know if its alright to bypass the coolant going threw the throttle.
It starts from the top of the radiator into the thermostat houseing then there is a hose running from the engine into the throttle, then from the throttle into the heater control valve. Now can i just run a hose from the engine into the heater valve. I believe the only reason it goes threw the throttle is to keep it warm for cold conditions, but not to sure if it well affect anything else
Thank You
Old Feb 20, 2012 | 07:12 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: TPI Throttle By Pass, Coolant every where
Yes u can their use to be a part number everyone would use for the hose but i just dnt know what it is or where i can find it i still havent gotten a chance to do this for the reasons i said
Old Feb 20, 2012 | 08:59 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
https://www.thirdgen.org/coolantbypass
Old Feb 20, 2012 | 11:34 PM
joeld's Avatar
Car: 1986 Firebird, 1989 Vette, 1995 GP
NAPA has a 5/8 hose with a 90* on one end. I would have to dig out some old receipts to find part number.
Joel
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
