Fan Problems
Car: 91 RS
Engine: 305 tbi
Fan Problems
I am having a weird problem with my single fan. The other day while driving home from work I heard a funny noise form the front and when I got home I found my fan no longer working. My car does not use the cts in the head as a previous owner had bypassed it when it went bad. (Found this out when I replaced the sensor and the fans still did not come back on when they should.) I relaced the fan motor with a used one from a wrecking yard and still no luck. With my research on here I thought it may have been fan motor relay but I tested that this afternoon and it is working fine. The fuse under the dash is also fine. I am now lost as to what the problem may be and electrical is my weakest area for my diagnostic skills. Any ideas would be greatly appreciated.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: Fan Problems
Check the fusible link off of the positive battery cable. Mine popped the link and the fan didn't work. There is also another fuse attached to the inside of the fender by the battery.
Car: 91 RS
Engine: 305 tbi
Re: Fan Problems
I found the problem, the wire that connects to the positive battery cable had broken causing the fan to not get any power.
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
Re: Fan Problems
my wife has a 86 trans am and its 305 tpi the single fan wont come on inless i take 2 wires and run them st8 to the battery the fan then comes on i changed the t-stat today to a 160 and i let the car get to 240 no fan come on at all what do you guys think it is could it be the relay by the air box and i did test the switch that plugs in to the fan its got no power at all with a test light with just the key on or the car running
Re: Fan Problems
and i checked the fuses in the car there all good to go.
Car: '91 1LE
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Fan Problems
Car: 91 RS
Engine: 305 tbi
Re: Fan Problems
no, the wire itself had broke. It was the wire that ran from the harness that the fan wires are in to the positive cable distribution block thing that is bolted between the radiator and the battery. I would have never saw it had I not been looking in the that area.
