Hisss from gas tank
Old 04-23-2012, 03:43 PM
greg69jones's Avatar
Hisss from gas tank
Okay when ever I go to fill up on gas (since this car makes me go there often) I twist the cap and sometimes there is so much pressure that it will shoot the cap into my palm with some decent force.
Any idea's what this is and if so what to do to fix it?
Old 04-23-2012, 04:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Hisss from gas tank
Just pressure built up in the tank. Normal but it really should be building high enough pressure to blow the cap.
But FYI.....You posted in the Cooling section. This has nothing to do with water/coolant or Cooling.
Old 04-23-2012, 05:01 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Yea this is normal. Just open the cap slowly or you can buy a venting gas cap from a local auto parts store if it troubles you to much.
Old 04-24-2012, 06:10 PM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
Mine does the same thing. Crack it open just enough to let the pressure out and then take off the cap. You want pressure in the tank, helps out the injectors.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Bohemian
08-15-2017 05:11 PM
amcnellis
09-16-2015 04:16 PM
TBRays98
09-06-2015 05:05 PM
Strick1
09-06-2015 10:38 AM
Quick Reply: Hisss from gas tank
