How many amps do the stock fans draw?
Old Apr 25, 2012 | 04:34 PM
zuma's Avatar
Car: 1969 SS Camaro, or 1990 Iroc vert,
Engine: 350 and 305
Transmission: tb350 and 700r4
I have a 1990 IROC. vert. A few years ago I added this kit to my Passenger side fan only;
http://www.summitracing.com/parts/PRF-30104/?rtype=1
It has worked great for me. My question is that I know the left side fan only comes on when the AC is running, but I was thinking in the summer months up here in the mountains I would like to tie both fans to come on at 190+/- degrees (I can adjust it). The relay and breaker is only rated for 20 amps, I don't think it would be too much draw to tie in both, what do you think? I don't think the A/C will be effected either way...your thoughts? Thanks
Old Apr 25, 2012 | 06:52 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: How many amps do the stock fans draw?
i tested a set of stock dual fans once and found each
motor pulled 7 1/2 amps once up to speed,accelerating
from stopped they pulled quite a bit more,perhaps
18-20 amps each motor for a couple seconds.probably
would be good to use a seperate relay for each motor.
If i had a third with dual fans i too would wire them to
run together or one to start right after the other if the
current inrush of the two starting together causes the
ignition to hiccup for a moment.
Old Apr 26, 2012 | 03:22 PM
zuma's Avatar
Engine: 350 and 305
This was in the instructions so I guess I am good to go...just need to splice into the other fan...
NOTE: WITH THIS RELAY YOU CAN OPERATE A FAN RATED UP TO 30 AMP'S OR
TWO FANS AS LONG AS THE TOTAL CURRENT DRAW FOR BOTH IS LESS
THAN 30 AMP'S
RazorN8
Jan 7, 2022 11:44 AM
Genopsyde
Oct 7, 2015 08:35 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Leggman1
Aug 6, 2015 04:15 AM
