idk what to do
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
idk what to do
my 305 tpi has a stock water pump but with a different serpentine belt rotation its all clockwise with the crank..the originall picture under the hood says to turn the waterpump counter clockwise but since my brackets are different idk if i should leave it the way it is because my stock waterpump is still pumping coolant at 180 degrees and the thermostat operates good..should i turn everything to stock rotation to not damage anything or will i be okay? please give me ur thought
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: idk what to do
does the top of the waterpump have a mounting lug
with a threaded hole?if it does that is standard rotation.
If there is no lug,reverse rotation for '88 up sepentine.
The pulley bolt pattern is different for the two rotations
with factory pumps.The pump will still pump the same
direction running backwards but flow will be reduced.
Re: idk what to do
Yes it does have a lug on top...does this mean im flowing right? Nd i appreciate all the help
Re: idk what to do
So if im spinning clockwise nd its correct with a lug like u said then y would the factory serpentine setup be counterclockwise? Its a 1992 firebird ta
Re: idk what to do
Ok i got u thanks..im gonna drive to atlanta from chicago il let u know how it runs ..thanks a lot
Car: '82 z28
Engine: L83 5.7
Re: idk what to do
seems someone swapped the waterpump and re-routed
the belt,perhaps in order to delete an accesory pulley...
