Runningt a 180 T-stat okay?
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Hello, i just installed at 180* mr gasket perf. t stat in my 88 camaro. Now, I was concerned about open loop and closed loop problems after reading topics. Will I have to worry about it with a 180* t stat?
Also, don't worry I have a adjustable fan switch with a manual over ride so i can control if i want to.
Should I just return it and go for the 195 t stat?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Runningt a 180 T-stat okay?
should be fine-only 15* difference and should be in
closed loop before 180 anyway.
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
computer is forced into closed loop after 190 seconds run time, unless certain cel's are set. thermostat rating won't matter.
180 T stat is fine btw.
Car: 91 Z28
not sure if you let it run long enough or not, but it definitely is set to go into closed loop on a timer. the min temp for closed loop is 109*F which should be easy enough even without any thermostat at all. but i was mistaken on the actual time, its 190 seconds, not 90 seconds, which i believe overides the actual temperature.
Engine: 4++,350 & 305 CIs
I've tried to get some heads out of bvtts but its hard... I get ssssoooooo sick of mis-information.
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
[QUOTE=TTOP350;5256239]You need to post this info on the threads when people say that a 160* T-stat will keep their car in open loop...
QUOTE]
My upper radiator hose is leaking a few drops out by the housing dripping onto the harmonic balancer. I re-placed the clamp, but it still will drip a little. So I'm going to change the T-stat, maybe its not opening all the way.
I was thinking of putting a 160* T-stat in, now after reading what you wrote is that a good idea? What temp T-stat is good to run? 160, 180, or 190? I have a 305 TPI.
QUOTE]
If its leaking out of the hose you may have corrosion between the housing and hose. A t-stat doesnt really cause leaks.
If you want to run a cooler t-stat, you have to make the fans run properly for the temp.
Engine: 5.0 TPI
Axle/Gears: 3.08
How do I change the fans to run properly if I'm using a cooler t-stat?
Hypertech has 2 fan switches, 1 for 180 an 1 for 160s. Do a google search for them.
88SS6SPEED
Nov 11, 2015 07:05 AM
Dragonsys
Sep 25, 2015 03:51 PM
