Curve in upper hose
Old May 8, 2012 | 09:28 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Curve in upper hose
Does anyone else have a problem where the upper radiator hose makes a sharp turn (after coming out of the radiator)? This is the second hose I've bought (AC Delco), and it wants to fold in that spot if I make it sit in that plastic holder thats connected to the radiator support. It doesn't overheat, so I know coolant is getting through, I just feel uneasy about it.
Old May 8, 2012 | 09:33 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Curve in upper hose
Fold how? The correct hose should already be formed & not need any force applied to make the turn, so even hot water flowing through it should not affect its strength in holding the bend in its correct form.
Old May 8, 2012 | 10:08 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
It is already formed, but after its on the car it tends to want to collapse a little right there where the bend is. I thought the last one I tried was a little too long, so I trimmed about an inch off, that helped a little. The last one was a cheap hose though, so that's why I went with AC Delco this time.
Old May 8, 2012 | 10:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hoses are trim-to-fit. If you're just sticking them on as they come, you'll have problems like that.
Old May 8, 2012 | 10:31 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Yeah I was hoping I wouldn't have to cut this one, but I may have to.
Old May 8, 2012 | 03:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Do your GM hoses have the lettering on them that says engine on one side?
You shouldn't have to cut those and they shouldn't do what your saying??
Old May 10, 2012 | 09:33 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I didn't see anything that says "engine", but I'm sure it's on the correct way. I tried to upload a pic but it looks like Photobucket is still down.
Old May 11, 2012 | 08:01 PM
TTOP350's Avatar
Sounds like the dealer may have ordered hoses from the same place you can buy them cheap.
The upper and lower will have white ink stampings on them. I cant find the pix of my NOS hoses
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
