Stainless hose length, fittings, and size
Old May 31, 2012 | 08:39 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Hello, im planning on replacing my transmission cooler lines that go into the radiator with stainless braided hose. I was wondering how much hose would i need to run both lines from the transmission to the radiator. Also what fittings would i need to adapt the an fittings to the transmission side and radiator side? And what size hose should i use, 4an or 6an?
Old Jun 18, 2012 | 11:45 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Stainless hose length, fittings, and size
I used 6an lines i cant remember how much i needed but i think i bought 15ft i can't recall but you could try to measure your stock lines to get an idea for how much you'll need... Also make sure you get teflon SS lines not rubber SS lines!! you'll need to get adapters for the for the transmission and radiator if i recall... ill try to remember to check this out since all be working o the car tomorrow i can't find my sheet with the parts i bought to do 6an transmission cooling lines... but ill take some pics and post them
Old Jun 19, 2012 | 06:52 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thanks man. I ordered 10 feet, hopefully that will be enough, and i found the adapters for the rad. Just to ask, why buy the teflon rather than the regular rubber? Also, when you unscrew the lines for the tranny, will the fluid leak out? Or just the excess in the line?
Old Jun 19, 2012 | 07:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need Teflon for ATF. You do need it for brake fluid.
Old Jun 23, 2012 | 03:41 PM
FueledSoul's Avatar
Originally Posted by camaro1122
Thanks man. Also, when you unscrew the lines for the tranny, will the fluid leak out? Or just the excess in the line?
No prob... Just the excess in the lines and radiator... as long as the pump isn't turning nothing else will come out...
True but it doesn't hurt! on the PS Teflon for sure!
Also here is some pics of mine for reference...
Top rad
Lower rad
Transmission
toronto formula
Nov 10, 2015 06:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
1985chevydude
Aug 20, 2015 12:29 AM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
