what temp should I be running, with a....
Old Jun 30, 2012 | 08:44 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
180* stat and a 195* Fan Switch??
Old Jun 30, 2012 | 08:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: what temp should I be running, with a....
Between 180 and 195 if your system is up to it.
Old Jun 30, 2012 | 08:57 PM
Car: 92 Camaro RS
Engine: 305 TBI
Thats what its been at, But lately my car has been in the 210-225 area. and it will slowly cool back down to 180-195 when at idle. air dam is fine could it be my water pump internals? I dropped a new 180 stat today and its the same. Radiators 1 year old (autozone special) and its holding its pressure. The only thing I can think of is the water pump...it looks origional I dunno. whats ur thoughts?
Old Jun 30, 2012 | 10:02 PM
Car: 92 Camaro RS
Engine: 305 TBI
I pulled the belt off and checked the water pump pully, I have some play in it. from what I understand there should be NO play in the pully correct?
Old Jul 1, 2012 | 07:34 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Check the weep hole in the bottom of the water pump. If there is any coolant leaking from it, that's also a good sign your pump is going out. Regarding the pulley, my new pump had no play in it. I don't think it should be much if any.
Steve
Old Jul 1, 2012 | 11:47 AM
Car: 92 Camaro RS
Engine: 305 TBI
The car is NOT overheating, its just running hotter than it normally does, I have NO coolant loss. I just drove it for 1.5 hrs and the temp stayed between 200-210, normally its 180-195. I pulled the belt off again, I do have some play in the waterpump so I picked up a new one. But what also concerned me was the pully below the A/C compressor and Tension Pully...that Pully Binds up at a 1/4 turn and breaks free and binds up again what is this pully and is that normal function for it? could this be why im running a little hotter?
Old Jul 1, 2012 | 12:00 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
You're not overheating, your heat is just over what it should be?
The water pump shaft should not have any significant amount of play.
The pulley you refer to is on the air pump. It has a cycle of resistance, but as long as it can be easily turned it is fine. In my experience when they seize up they tend to do it in style.
Old Jul 1, 2012 | 12:20 PM
Car: 92 Camaro RS
Engine: 305 TBI
Over heating but not a dangerous overheating, it wont climb to weher i have to pull over. So that resistance in that air pump is normal?
Old Jul 1, 2012 | 08:42 PM
Car: 92 Camaro RS
Engine: 305 TBI
I replaced the waterpump, I drove it around for about 20 min. to test it out, Its night time so its alot cooler out but it still went up to about 210. I cant figure this out its strange and after I park and let it run it will drop back slowly to 195. Any ideas?
eightsixseven
Dec 16, 2024 01:50 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
