temp jumping????
Old Jul 9, 2012 | 01:03 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
temp jumping????
so when i first start my car it heats up fine. stays right around 165* i believe thats normal for a 3.1 camaro not to sure. but then after a while it heats up to around 220* then cools back down to 165* then goes to about 250* then back down to 220* then back and forth, i feel like i cant keep my eyes off the temp gauge cause i dont wanna over heat it. any suggestions on how i can get this under control???? everything on the car is stock. suggestions are appreciated
Old Jul 9, 2012 | 03:24 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: temp jumping????
Firstly, check your temp gauge for accuracy against something else, like a laser temp gun.
If it's not lying, then sounds like maybe your fan(s) aren't staying on when they should be. Are the fan(s) off when it heats up?
Old Jul 10, 2012 | 03:34 AM
Car: camaro
Engine: 3.1
Transmission: auto
i havent been able to tell if the fans are on. when its sitting and the temps are up the fans arent on. but if i turn the a/c on then the fans go on. ill give it a better look when i get the chance. what part tells the fan to go on??
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
