A/C conversion
Old Jul 20, 2012 | 04:55 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
A/C conversion
So I'm switching over to use R134a refrigerant and ordered the conversion adaptors. Replaced the compressor and clutch, dryer, accumulator and condensor. I find out that the high side adaptor is nothing more than a threaded coupling, open on both ends with a cap. Is this correct ? Anyway I found out that I'm leaking at the schraeder valve on the hi-pressure aluminum tube when I was filling the system with 134a freon. This may have been leaking for years as I was re-charging the system with R12 every season. Now I can't find anyone that carries R12 and they want to convert over themselves. You cannot find these OEM tubes anymore new. What I'm thinking is to put a plug in the conversion adaptor as one shouldn't be trying to de-pressurize the system on the hi-side anyway.
Old Jul 20, 2012 | 10:14 PM
drjewalton's Avatar
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
Re: A/C conversion
I, too, converted my 84 to r134 and had the very same leak in the same spot. I purchased a used tube on eBay from an 85 (still has r12 fitting) and was going to replace the whole tube and retro fitting. Problem was I didn't know for sure if the eBay tube was good or if it leaked at the valve too.
Long story short, I ended up using an aftermarket high pressure tube already fitted with the r134 fitting. Cost around 30 bucks and doesn't leak.
I still have the eBay tube if you want it (cover my shipping costs). You would still have to put a retrofit r134 high pressure fitting on it. Tube looks like its in good shape but I have no idea if it will hold pressure or leak.
Let me know if you're interested and pm me your address/zip and I can get shipping price.
Next time I get a chance, I'll shoot some pics of the tube as well as the aftermarket tube I actually used for my car. Not sure if camaro and Pontiac parts are interchangeable.
Old Jul 22, 2012 | 07:19 PM
DrDoom's Avatar
Car: 1991 Trans Am GTA
Engine: 5.7 l
Re: A/C conversion
Did you use a Sanden compressor? I just put a new Sanden 5411 in mine, still need to get a longer serpentine belt and bolt. The reason I ask is that the tech article says to remove the pressure switch located on the back of the R4 compressor using snap ring pliers, but I'm not sure where to re-attatch it.
Old Jul 22, 2012 | 07:48 PM
djmarch's Avatar
Engine: 5.7 ltr.
Re: A/C conversion
You need your hi-pressure switch to make your system operate correctly. It also controls your cooling fans through the ECM....I'n not familiar with a Sanden. I switched mine over to an OEM Delphi. You should have a port on your Sanden if it's compatible. There may be an aluminum plug behind the snap ring.
Old Jul 22, 2012 | 08:29 PM
DrDoom's Avatar
Engine: 5.7 l
Re: A/C conversion
There seems to be a fitting on the back of the Sanden compressor below the suction and discharge ports. I'm not sure what it is. I've been trying to get some info on it but the closest description I seem to get is that it's a "service port." I guess I'll try to take it off and see if the pressure switch fits in it.
Old Jul 23, 2012 | 01:50 PM
drjewalton's Avatar
Transmission: TH350
Re: A/C conversion
Here's some pics of mine with the new high pressure hose. It was actually fabricated at the shop that did the a/c conversion work. Costs for parts about 46 bucks. Works well so far.
Attached Thumbnails A/C conversion-img_2362.jpg   A/C conversion-img_2361.jpg
Old Jul 23, 2012 | 01:55 PM
drjewalton's Avatar
Transmission: TH350
Re: A/C conversion
Here's the OEM high pressure tube: (For comparison)
Old Jul 24, 2012 | 12:16 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: A/C conversion
You should simply change to freeze 12 refrigerant. It takes the same oils as r12 so you don't change anything.
Old Jul 24, 2012 | 03:15 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: A/C conversion
Be careful, those plugs are under pressure from the factory
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
