cooling issues
Old Jul 29, 2012 | 01:58 PM
slayers90RS's Avatar
Car: 1990 RS Camaro
Engine: 305 c.i. v8 tbi all stock
Transmission: 700r4 bone stock
cooling issues
Hi guys im new to this forum, I think im posting in the right place but if not just point me in the right direction. Anyway i have a 1990 RS camaro 305 tbi. From what I've read so far i understand that these cars tend to run a little on the hot side and thats a normal thing. So when my car runs at 220ish it hasn't bohtered me until today when the SES light came on standing at a light. Once i started driving the temp gauge went down and the light went off. Has this happened to anyone and what can be done about it. Im waiting on a buddy to bring me a code reader so later on i can post the code if that helps. any help is much appreciated.
Old Jul 29, 2012 | 02:02 PM
Car: 1990 RS Camaro
Re: cooling issues
Also I have a brand new radiator, upper and lower hoses, tstat with whatever the OE specs are(180* or 192*?)
Old Jul 29, 2012 | 03:48 PM
92convertible92's Avatar
Re: cooling issues
I am having the same problem so if you getb any info share with me please.
Old Jul 29, 2012 | 05:37 PM
Z28Johnny's Avatar
Re: cooling issues
this is a great topic to do a search on. There is an unreal mount of info about cooling our cars.
Old Jul 29, 2012 | 08:47 PM
Car: 1990 RS Camaro
Re: cooling issues
Will do man, Its driving me insane. Im going to find out what the code was tomorrow and troubleshoot from there, Ill keep you posted.
Old Jul 30, 2012 | 05:35 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: cooling issues
I had an issue when I swapped in my 350 for my 305. The car ran hotter and since the carb wasn't tuned, my emissions was off. The light would come on in traffic then when the engined cooled it would go off. Once I got everything tuned back up, the light stayed off. That said, based on my experienec, when your car gets hot, it's changing how the O2 sensor is reading, which is why you're getting the "soft fault". the computer doesn't like how it's reading. As long as the fault goes away, I wouldn't worry about it all that much. Check your O2 sensor, EGR and make sure your "dialed in", could be an indication that a sensor is going bad.
Old Jul 30, 2012 | 10:30 PM
Car: 1990 RS Camaro
Re: cooling issues
you could be right about that. Today i was driving it around to try and make the light come on and it did before the car even got hot. within a minute or two the light was off again. This made me think its no longer a cooling issue because the car has never overheated once. It could very well be a sensor going bad then.
Old Jul 31, 2012 | 06:20 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: cooling issues
Is your fan running when these temps go up?
Old Aug 2, 2012 | 06:44 AM
Car: 1990 RS Camaro
Re: cooling issues
yes it is, i double checked to make sure it comes on and it does so right around 220* every time.
Old Aug 4, 2012 | 03:20 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Re: cooling issues
have you tried to run a OBD1 scan to pull the code? you can check the number of flashes with your car off and acessories on, use a paper clip or piece of wire and jump the upper row last two pins together.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
