Trans Cooler leak?
Old Aug 1, 2012 | 09:34 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Trans Cooler leak?
I think I found my heating problem and idle problem. I double checked my tranmission fluid and it was low and PINK. I have serious reson to believe my transmission cooler is leaking and mixing with my coolant.
Old Aug 4, 2012 | 10:45 PM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Re: Trans Cooler leak?
The only place the coolant and trans fluid are near each other is in the radiator
i guess that the radiator failed internally and is allowing the two to mix rather than failing with a visible leak on the ground.
im not sure how to test the radiator for this but if you have the money to throw at it i would get another radiator and a trans filter and fluid change.
Old Aug 5, 2012 | 08:47 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
If the above was true he wouldn't be low on fluid.
Old Aug 5, 2012 | 10:37 AM
jez3941's Avatar
Unless the trans fluid is being pushed into the coolant more that the coolant is coming into the trans.
check to see if the coolant is starting to get a redish tint to it
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
