What CFM are the stock fans?
Old Aug 8, 2012 | 01:01 PM
Guest
Guest
Posts: n/a
Old Aug 8, 2012 | 04:22 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: What CFM are the stock fans?
not sure. just buy some 4th gen fans and stick them on there.
Old Aug 8, 2012 | 05:38 PM
Guest
Guest
Posts: n/a
Im swapping the stockers out to chase even cooler temps (blower setup, moving to Florida, and wiring them to the battery and to a switch) and more space in serpentine belt/blower pulleys. Iv bought 1 so far and its a 12" FD S blade (alleged 1600CFM) and a stock fan feels like its blowing more than the new 1.
-The next 1 will be a 14" flat blade rated at 2000CFM .
Old Aug 8, 2012 | 11:42 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have driven mine on plenty of 100*+ days when it had the stock single core radiator, stock single fan and a 190* thermostat. When everything is working correctly and the engine is tuned correctly you can do a decent cooling job with just those.
Old Aug 9, 2012 | 12:59 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Taurus fan (91-95 3.8l) is 4500cfm. I just installed one and it is by far the best fan I have ever used. The 14 inch fan would make a good pusher. I had one on a previous set-up and it worked well.
Old Aug 9, 2012 | 11:17 AM
Guest
Guest
Posts: n/a
Iv heard about that fan and their just so happends to be 15 91-95 Tauruses in the puu a part by me but most (nearly all have been their awile, iv only looked on the website but I may or probly will go their today.
Old Aug 9, 2012 | 04:12 PM
one92rs's Avatar
Car: SOLD!!!!!
for a stock setup a stock fan will work. when a blower or more performance parts are added it can heat an engine up quicker thus needing a better cooling system.
Old Aug 9, 2012 | 04:13 PM
Guest
Guest
Posts: n/a
Are all the 14in fans the 1s im looking for? I looked for awhile and I had a head ache and was very tired but I still checked nearly all 15 cars spanning some 30 isle and all were dual 10/12s I saw a 14 and I said fk it and got it. Will put it in-in the next few days.
Old Aug 9, 2012 | 05:44 PM
Tibo's Avatar
Car: 1991 Z28 Vert
That is true, yes. However many people have it in their heads that their sbc, boosted or not, needs a cooling system with the capacity to cool a twin turbo big block in a towing vehicle. My post was simply to illustrate a point that you do not need to scour junk yards or pay abhorrently high prices for a cooling system. And although it may be a moot point, in my example the engine I had at the time was a decently cammed 355 daily driven car.
Old Aug 9, 2012 | 07:21 PM
one92rs's Avatar
Car: SOLD!!!!!
i am aware of all that. a boosted engine will run warm quick with rising intake air temps. had one. beginning of a run 90*. end of the same run 115 to 130*. which equals more heat.
i will agree that a stock cooling system in perfect working order will cool 80% of all engines in the car. most go well overboard in their pursuit of the (believed) cooling system needed.
Old Aug 10, 2012 | 05:39 PM
Guest
Guest
Posts: n/a
Any body have an answer to my last post?
Old Aug 11, 2012 | 07:16 AM
one92rs's Avatar
Car: SOLD!!!!!
either 12 or 14 if they are dual fans. if you are looking at junk yards then pull a set of fans off a 1993 to 2002 camaro or firebird.
Old Aug 11, 2012 | 04:41 PM
Guest
Guest
Posts: n/a
the 14in fan I pulled was a single with a shroud, ill take a pic when I get some time.
http://www.carpartsdiscount.com/auto...tml?3593=46117
pretty sure its that 1, the fan is in my trunk/hatch.
Old Aug 11, 2012 | 08:45 PM
one92rs's Avatar
Car: SOLD!!!!!
that said it is a taurus fan. those cool really good.
Old Aug 12, 2012 | 09:55 PM
Guest
Guest
Posts: n/a
Pics on Monday, might even mount it then too.
Old Aug 13, 2012 | 08:58 PM
Guest
Guest
Posts: n/a
-for sale $30 shipped, works good, just going a different direction now.
Old Aug 15, 2012 | 06:56 PM
Guest
Guest
Posts: n/a
Old Aug 17, 2012 | 08:28 PM
Guest
Guest
Posts: n/a
Bump? Still have this for sale.
Dose any body know the cfm of the stock fans?
beastin91rs
Oct 9, 2015 07:38 AM
Genopsyde
Oct 7, 2015 08:35 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
