Stewart Water Pump...???Replacing my water pump...
Old Sep 1, 2012 | 10:11 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 1984 Z28 5-speed and I am in the process of buying a new water pump but I dont k now on whether I should buy a O'Reilly Water pump for $45 or a Stewart water pump for $85...?what exactly is the big difference?Im just trying to get my car to run again without overheating....and for stewart exaclty which pump fits my car...thanks..
Old Sep 2, 2012 | 09:00 AM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Re: Stewart Water Pump...???Replacing my water pump...
Why is your car overheating? Is it just because of the bad pump or is there other issues?
I have a Stewart Stage 2 pump which I installed to help cool the engine I had built, I was concerned that the stock pump would have a harder time cooling the new engine.
If the stock pump was cooling ok before it went out I would stay with the stock pump ( it is half the price and should last). I looked on O'Riely's website and it looks like you can get a new Masterpro pump with a lifetime warranty under $50.
If you have alot of mods in your car and you think your stock pump is not keeping up go for the Stewart it is an excellent pump and I am very happy with mine.
http://www.stewartcomponents.com/Stewart_faq.htm
Old Sep 2, 2012 | 10:45 AM
calgutie's Avatar
Car: 1984 Z28
Ye.. I am pretty sure that its my water pump becuase I removed the thermostat and took off theupper radiator turned on the car and nothing would come out fo the hose only every so often wold small ounces of antifreeze come out, which leads me to beleive thaqt the WP is stuck.....I might just end up going with a stock one becuase I dont really have any mods the engine is pretty much stock just trying to get it to run without overheating on me......
PS: I let the car sit for about 5 minutes in the driveway while turned on and it stvarts overheating.
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
