How do you remove the condensor
Old Oct 20, 2012 | 09:44 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Now that I've removed the evaporator, thanks to your help.
I would like the same step by step instructions for removing the condenser.
I've removed all the AC parts with exception of the compressor which is new and I want to leave in and condenser. Thanks for any help.
Andy
Old Oct 20, 2012 | 09:50 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Re: How do you remove the condensor
shoot where in the same boat...im trying to do the same...
Old Oct 20, 2012 | 10:19 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
super easy-much easier than removing the evaporator-just disconnect the refrigerant lines,remove the upper rediator support or upper fan shroud half,lean radiator back a little and withdraw condenser
Old Oct 20, 2012 | 10:28 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
thanks
Old Oct 20, 2012 | 10:34 PM
calgutie's Avatar
Car: 1984 Z28
Old Oct 23, 2012 | 04:58 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Do I need to remove the entire fan shroud. I unbolted the 4 bolts to the shroud that is on top of the radiator pushed the radiator as far forward as I dared and wasn't nearly enough room to lift the condenser out. the condenser has no fasteners except the shroud that keeps it in front of the radiator correct.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
