Fan will not go on.
Car: 89 Firebird
Engine: 2.8L
Transmission: TH700r4
Axle/Gears: 3.43
Fan will not go on.
I have a 89 Firebird 2.8L and the fan will not go on with the car on. If I put a scan tool and the fan goes on. So it WORKS but my buddy says if you turn on the A/C the fan should go on. It doesn't. But I don't know if its because I can only do to the second power setting then it shuts off. But anyway, I replaced the relay, and the cooling fan sensor switch and still nothing. My firebird gets to 240 and stays put unless its city driving. City driving it slowly rises (I'm assuming because the fan doesn't work) water pump seems to work, with the radiator cap off when I rev the motor the coolant sinks and rises when I let off it. I also changed the radiator and I put the Air damn on.
What's next?!
What's next?!
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: Fan will not go on.
fan switch, coolant temp sensor, test relay
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Nick White
My firebird gets to 240 and stays put unless its city driving. City driving it slowly rises. What's next?!
No Air Dam under the car is the reason for high temps on highway. Cooling fans only work to about 40mph, so you are ok in stop and go city driving.
gta892000
Sep 16, 2015 12:37 AM
