Thermostat housing bolt feels like it will snap
Old Nov 25, 2012 | 06:43 PM
baileysup's Avatar
I tried to swap out my thermostat the other day and one bolt came out fine, but the other gave me a few good turns, and then became very tight. Obviously, I don't want to snap this thing off inside my manifold, so are there any procedures that I can try to get it out in one piece? Maybe some heat? I guess my only other option would be to drill and tap it? Any info is greatly appreciated.
Old Nov 25, 2012 | 06:49 PM
baileysup's Avatar
Re: Thermostat housing bolt feels like it will snap
Or maybe it's time to upgrade the stock intake......
Old Nov 25, 2012 | 06:51 PM
Guest
Guest
Posts: n/a
"If at first you don't succeed, apply brute force."
Old Nov 25, 2012 | 06:55 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Heat, lube repeat until its loose. Then use a thread chaser and antiseize on the new bolt threads.
Old Nov 25, 2012 | 07:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
soaking down the bolt with pb blaster and applying direct heat with a propane torch after you get the bolt real hot you can shock with a hammer, do this several times and even heat it up and press a hammer on the bolt the heat will dissapate toward the manifold hopefully loosing the threads. If you are able to remove it clean the bolt or stud threads real well and use antiseze on the threads.
Old Nov 25, 2012 | 07:29 PM
baileysup's Avatar
Hey thanks. Will do
Old Nov 25, 2012 | 07:36 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Let it soak in PB blaster and instead of just trying to remove the bolt turn it back in some then back out a little more than before,turn back in then out, then again and again until you get it.
Old Nov 25, 2012 | 08:16 PM
baileysup's Avatar
Yes ronusmc. That was exactly the method I was using when trying to get the bolt out. It seemed to not be progressing any farther using that method, so that's why I think I need to try the propane torch and possibly the hammer procedure as tunedperformanc has described. It's definitely worth a shot, but the last thing I want to do is snap this thing off in the manifold, cause this isn't a project car. This car is a daily driver, and my only means for transport right now.
Old Nov 26, 2012 | 07:53 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
I just went thru this last month when changing mine... Snapped the inner stud... Ended up grinding the top flat with my dremel and drilling out the bolt starting from a very small drill bit size dead center and progressing up a size until I got to the correct size down for my tap,,, then simply tapped out the remaining threads of the old bolt... I then used stainless bolts from the local hardware store when reinstalling with antiseize... Take your time if you do snap it, not all is lost... Didn't take that much time if you have the correct tools... Next is my distributer hold down bolt which feels the same... I'm only 1 degree off in my favor, so, I probally just leave it... Hopefully you'll get it out, but if it does snap, plenty of options to save it..
Old Nov 26, 2012 | 09:44 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
As a last resort, since you can get it to turn you might be half way there. You could grind the head off, take off the housing and just turn the bolt like you are tightening it until it drops into the water jacket, then remove it thru the thermostat hole. Anybody see any reason this won't work? I don't know how much bottom clearance their is or how hard it would be to grab the bolt shank one it dropped into the water jacket of the intake.
Old Nov 26, 2012 | 09:47 AM
Engine: Lb9
Transmission: M20
Uh yeh wont work
Old Nov 26, 2012 | 11:41 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Originally Posted by tunedperformanc
Uh yeh wont work
Well, tell us why. Is it too long and will hit before it drops out, or what exactly? He seems to have it loosened, it just won't back out because of rusted threads hanging in the water jacket.
Old Nov 26, 2012 | 01:05 PM
Engine: Lb9
Transmission: M20
The thermostat bolts should be into casted bosses.
Old Nov 26, 2012 | 01:41 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Ok, I figured his wouldn't back out because the threads sticking into the water jacket were rusty and that's why it would jam when trying to back it out. But I guess they don't stick into the water.
Old Nov 26, 2012 | 02:21 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
I've broke them before, drill and retap is about the best bet. If I had the time I'd install a couple of studs in the intake and then hold the waterneck down with nuts rather then the bolts so even if coolant gets down in the threads and corrodes it up i'll still be able to get the housing off no problem.
Old Nov 27, 2012 | 07:13 PM
baileysup's Avatar
OK, It's easy. If I can't get it, It's drill and tap, or new manifold. Can I drill and tap while leaving the manifold on the engine? What are the consequences of drilling it out with the manifold still on the car?
Old Nov 27, 2012 | 07:16 PM
Engine: Lb9
Transmission: M20
only if you drill to deep
Old Nov 27, 2012 | 07:44 PM
baileysup's Avatar
Ok, thanks, but wont the metal shavings get caught up on top of the piston? Or will they blow through
Old Nov 27, 2012 | 07:47 PM
Engine: Lb9
Transmission: M20
you will be drilling into the valley if you go to deep.
Old Nov 27, 2012 | 07:52 PM
Hopefully you'll get it without having to resort to drilling it out. but if so, I just took the water neck, put the other good bolt thru the hole from the top side, put my drill bit on the bottom side next to the bolt threads for depth, wrapped some masking tape around the bit at the bottom of the bolt threads and went to work...
Old Nov 27, 2012 | 08:03 PM
baileysup's Avatar
Ok, I know what I have to do, but may not do it till spring. Thanks everyone. You've been many helps
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
perZ
Aug 15, 2015 01:17 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
