oil cooler ,good or bad?
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
I have a 1990 camaro z28 with383 and world class t-5 and rad from an auto , I was thinking of using the trany res in the radiator and conect oil lines to use it as an iol cooler . any thoughts ? any body done this? how mutch will it cool ? ect.? thanks in advance!
Re: oil cooler ,good or bad?
oil cooler for what? engine? lines too small, not capable of pressure and if sprung a leak a nice engine full of coolant. For the tranny? You'd need a pump to be able to do this and have a pikcup port that you will not scrape off when a fitting is connected to it.
Bad idea IMO. If you want/need an engine oilcooler, get something with -10 lines minimum
Engine: 4++,350 & 305 CIs
Agreed, bad idea. If your car came with the 305 5spd and 342 gears, chances are it has a factory oil cooler between the block and filter. It works, not the greatest but it does work.
There is a oil cooler thread some place that tells of 2-3 other factory oil coolers that work.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Are oil coolers really necessary? Isn't an oil pressure gauge and engine temp gauge enough? I mean how hot can engine oil really get to make it dangerous? I can see this being necessary for race engines that run at high RPMs for long periods of time, but what about street?
Car: 1990 z28
Engine: 5.0
I would think an oil cooler is important . the cooler the oil the less viscosity breakdown meaning superior lubrication, extended oil life , and in some cases more compression, so I look at an oil cooler like a radiator , how important is a radiator ? yes I know there is a big difference . but anything to keep the engine cooler is a pluss in my eyes.
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Yes
NO
at about 270* F conventional oil starts to break down.
it's not uncommon to have oil temps on the street at 200* constant, and it of your warter tem is running hi, using an oil cooler will also dissipate engine heat.
that is just normal driving, then add traffic and it is easy to get to that oil break down point.
the service scedual on new cars is as short as 3000mi, and some times that's to long! the wife's car, 2010 RX8-R3, with an oil cooler at 2500 mi the oil is black!
oil cooler for engine and auto trans is very necessary! 7-10 rows on each, and they must have a thermostat. so the oil gets up to operating temp which is just as important as keeping it from getting to hot.
race cars should get a cooler for a manual trans and the deferential/s
Yes
NO
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Black oil doesnt mean that its bad and needs replaced all the time. Yes you dont want engine oil getting too hot but you also dont want oil to cool either. 210-220 degrees for oil aint bad it also helps burn moisture that gets in there.
Yes
NO
Yes
NO
What do you mean, oil cooler for our cars? Buy a moroso remote filter/cooler adapter or an earls thermostatically controlled one, run -12 lines and hook it up to a -12 AN oil cooler... no problem at all! All youi need is universal parts
Here's my oil cooler setup on a 77 corvette, it's thermostatically controlled by a CV products thermostat:
cv prod. thermostat (the black thing)
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I also run a large engine oil cooler that comes on at 180* using a thermostatic sandwich adapter . The 180* on temperature allows the oil to reach a decent running temperature and for me that seems to be a good design. My car is a auto. so I also have a extra cooler for that.Mine is not some thing the "op" would want because its a combo cooler but it does show a variation of whats out there for our cars.
http://www.summitracing.com/parts/DER-15903/
Navy8125
Aug 21, 2015 09:32 AM
