coolant hose will not seal, keeps leaking
Old Feb 7, 2013 | 01:20 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i purchased an aftermarket overflow tank with a 1/4" smooth fitting on it, not barbed, and i cant get the 1/4" hose to seal on it, it just keeps leaking slowly. i've have issues like this in the past with various other cooling lines, and an easy solution for it was to put an extra hose clamp on it, but this thing will not seal even with 2 hose clamps on it, and i tighten them really good. you can even twist the hose a little bit and tell its not tight, i wish it was barbed so it would fit better. anyone have any tips on what to do to make this seal?
Attached Thumbnails coolant hose will not seal, keeps leaking-20130206_154705.jpg
Old Feb 7, 2013 | 05:12 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: coolant hose will not seal, keeps leaking
Rough it up a lil bit with sand paper?
Old Feb 7, 2013 | 05:15 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Smaller hose? If you can still move it tightened down is the hose too big?
Old Feb 7, 2013 | 06:51 AM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
If the hose is too big yu can buy a smaller hose or you can make up the diference with Teflon.
Old Feb 7, 2013 | 09:29 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Does the hose slide on and off without resistance? If so, it's too big.
You could use a smaller hose an a light film of vaseline, makes installation and especially removal much easier!
Old Feb 8, 2013 | 01:34 AM
QuickStyle's Avatar
Car: 91 Z28
i was using fuel line hose, i got the idea to try thinner walled hose cuz it might seal better with less rubber that the hose clamp needs to compress , so i picked up some 1/4" windshield washer hose and it seems to be holding up fine, not leaking. thanks for the help.
Old Feb 19, 2013 | 12:22 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
that fuel line tubing doesn't work on coolant hoses - whatever it's made out of is not compatible with coolant. i had a similar problem years ago, except that it just kept cracking and leaking...
Old Mar 8, 2013 | 08:12 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Plus coolant is way hotter than you fuel and for sustained periods
Bubbajones_ya
Jul 6, 2024 08:32 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
bamaboy0323
Sep 12, 2015 07:14 PM
m00n420
Sep 11, 2015 02:39 PM
hdis2002
Sep 8, 2015 02:52 PM
