How do i wire the fan to come on with engine? Help!
Old Mar 6, 2013 | 06:31 PM
DARKD3CIMATION's Avatar
Transmission: 5 speed manual
The previous owner had a toggle switch but it kills my battery and sometimes I might forget to turn it on when I'm in a rush, how can I wire the fan to come on when the engine comes on, the ECM is removed, can I just ground it to the frame and run a hot wire to the fuse box under the strafing wheel and wire it to a 15amp fuse? Or will it come on when I just turn the key but not start it?
Old Mar 6, 2013 | 06:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How do i wire the fan to come on with engine? Help!
https://www.thirdgen.org/forums/cool...n-problem.html
Old Mar 6, 2013 | 09:32 PM
But I want the fan to come on when the engines on and stay on. It's 86 camaro Irocz quadrajet.
Old Mar 6, 2013 | 10:30 PM
Engine: Lb9
Transmission: M20
its not that great of a idea to run a electric fan continuously. If you have a pusher or a puller the air drag will takes its tole on the fan motor. If you want better control look at the schematic on the link and ad a switch on the coltrol side of the relay just in case the ect switch fails. aother way would be to go with mechanical fan and fan clutch. If you are determined to have the fan all the time use a bosch style relay and hook the trigger coil side to a switch ignition source.
Old Mar 7, 2013 | 09:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Find +12V that is only on with the ignition. Wire that to the coil of a relay. Then wire the switch part of the relay inline with a fan.
Old Mar 8, 2013 | 08:02 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
This^^^^
Old Mar 8, 2013 | 08:05 PM
Ingram78's Avatar
Car: 1985 firebird
And did you know also at low voltage there isn't enuff current to switch the relay on.....ask me how I know.
I'm using the original 2.8 fi puller fan on a oem single core radiator
Old Mar 8, 2013 | 09:36 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Use a very simple adjustable thermostatic electric fan controller like the one I'm using.
You adjust the switch so it comes on when you want it to automatically.Then (if I remember correctly)shuts off when it hits a temp. 10* cooler than the setting.
http://www.autozone.com/autozone/par...artNumber=true
It dose not get any simpler than this =
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
