Cooling fan wont shut off after new fan switch
Old Feb 13, 2013 | 10:14 PM
kenwood1609's Avatar
Car: 1989 firebird formula
So I have been working on putting in a 350 into my 1989 firebird formula and when I was doing the motor swap I broke the fan switch off. So after I got a new one I installed it and the fan just comes on when I turn the key on so does anyone have any ideas i really dont wanna pull it back out but I really want everything to work as it should.
Old Feb 13, 2013 | 10:22 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Cooling fan wont shut off after new fan switch
3 likely possibilites:
1) The switch is defective and will not shut off.
2) The wire is shorted to ground somewhere between the switch and the relay.
3) The relay is jammed on.
Old Feb 13, 2013 | 10:35 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
had same issue on my 87 z there was a tiny nick on the wire grounding out, id take a look closely at the wirig
Old Feb 13, 2013 | 10:48 PM
Im not sure what to do because when I unhook the pig tail from the switch the fan shuts off but then it comes back on if I plug it back in is there a way I can un jam the switch maybe unhook the battery and hook it back up?
Old Feb 13, 2013 | 10:49 PM
Also when I ground the wire to the frame the fan comes on so I dont think its a problem with the wire itself but I could be wrong
Old Feb 13, 2013 | 10:54 PM
Then you left with either a short somewhere from switch to relay or bad switch, short is much more common than bad switch
Old Feb 13, 2013 | 11:06 PM
Do you think there could be a short inside the pig tail I had alot of trouble getting it to clip onto the new switch so i gave it a little push with a screw driver??
Old Feb 13, 2013 | 11:28 PM
id take a close look at the connector good thing is there's really only two possibilities now just a little troubleshooting, is it a dual fan setup? if so there is two relays you can switch the connectors and if problem persists you can rule out the relay
Old Feb 13, 2013 | 11:39 PM
No its not a dual fan setup it just has one fan
Old Feb 13, 2013 | 11:41 PM
take a close at the connector
Old Feb 16, 2013 | 08:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You have a faulty switch. Buy a new one, replace, take replaced back for refund.
Old Feb 16, 2013 | 08:55 PM
I did this and they gave me the wrong switch this time the one they gave me is made for a dual fan setup and im running a single fan setup the switch they gave me does turn the fan on and off but not at the right temp the fan now comes on at 236 so hopefully the third switch I am getting will solve the problem.
Old Feb 16, 2013 | 09:02 PM
deadbird's Avatar
Engine: TPI 305/ v6
All switches turn on at 238 regardless of motor/year/fan array (excluding tta i believe).
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
