Transmission Cooling Line HELP!
Old Feb 15, 2013 | 05:33 PM
bglancer71's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 700 R4
The transmission cooling line that goes on the bottom of the radiator is leaking oil. Is there a way to repair the line inlet? I can't find a cooling line for sale at an autoparts store or online (been looking for 3 days). They also have a rubber hose as a replacement but it doesn't seem safe and efficient. I really need the car been using a loner car from my dad. I'm also not interested in getting a seperate cooling system as I only use the car for daily driving no track use or racing. Thanks.
Old Feb 15, 2013 | 07:03 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Transmission Cooling Line HELP!
I've used rubber hose many times. I would use at least 2 clamps on each end. Use the correct type of hose. The other option is replace the whole line.
Old Feb 16, 2013 | 08:21 AM
The lines are readily vailable everywhere as "brake line".
The size is 5/16" inverted flare.
Just ask the g00b at the counter at yer local AZ or Advace or whatever, to let you go back and LOOK AT his store's brake line; and pick out a stick of suitable length.
Old Feb 17, 2013 | 04:38 AM
bglancer71's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Thanks. I am just iffy about it because of temperature from exhaust and all, have your resisted the heat from it?
Old Feb 17, 2013 | 04:42 AM
bglancer71's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Thank you. I have some time tomorrow morning before my 3pm-12am shift and will go buy some and try to get it on.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
Leggman1
Aug 6, 2015 04:15 AM
