Interesting thing happened..
Old Mar 13, 2013 | 07:38 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
My car always ran stable at 180-ish degrees. Rebuilt the distributor, now it runs at around 220. The temp is stable, so Im really not concerned of overheating, just wondering why the sudden change. Any ideas??
thanx.
Edit: I do not know the T-stat that is in it.
Old Mar 13, 2013 | 08:13 PM
Guest
Guest
Posts: n/a
Re: Interesting thing happened..
The timing got changed in the process...let me guess, you didn't re time the motor.
Old Mar 13, 2013 | 08:40 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the only thing it could be is your timing is a little different . good luck .
Old Mar 13, 2013 | 08:43 PM
Veaceonee's Avatar
I dont know what the timing was before. But, the sticker on the hood says 6* and it is at 5. Could 1 degree make such a big difference?
Old Mar 15, 2013 | 05:03 AM
Veaceonee's Avatar
Been doing a little experimenting. Temp is right where it normally is, as long as the AC is off. Turn on the AC temp climbs, and will keep climbing (never let it get past about 230ish). Turn AC off, temp will come down, but VERY VERY slowly. Thoughts?
Old Mar 15, 2013 | 05:09 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
How's general driving performance? Does it pull as usual or is it sluggish?
Did you pull the EST connector apart before checking the engine timing?
Old Mar 15, 2013 | 05:13 AM
Veaceonee's Avatar
Driving performance is about the same, starts better. When I checked timing I forgot to pull the EST connector , but the distributor went in the same exact spot (rotor,shaft, and distributor base to manifold were all marked).
Old Mar 15, 2013 | 06:19 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Check again with the connector disconnected. You'd be surprised
Orr89RocZ
Apr 25, 2016 08:28 AM
Mickeyruder
Sep 2, 2015 02:45 PM
overdriv
Aug 20, 2015 03:52 PM
Bob88GTA
Aug 18, 2015 03:31 PM
