4th gen air dam... very efficient!
Old May 31, 2013 | 05:20 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Well, long story short, was having major cooling issues after trying everything I could think of.
Thanks to the very helpful guide:
https://www.thirdgen.org/overheating
I realized my car needed an air dam! Never had one on there when I bought it many years ago. Went to the JY and fabbed this up quick and holy hell, it worked.
I am concerned that it may be running too cold now?
Started with this
Jigsaw!
Doesn't budge from this temp on the highway anymore. Only rises during city traffic. I have a 170* stat by the way.
Old Jun 3, 2013 | 04:44 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Heated Discussion
The gage might be off, but from the photo, looks close to indicating 170°.
These gages are logarithmic, not linear, therefore the line between 100° and 220° is near 180°, not 160° as it would be if linear.
So that would mean your 170° stat is doing it’s job.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Jun 3, 2013 | 05:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 4th gen air dam... too efficient?
If you were really wondering shoot the thermostat housing with a IR gun (if you have one or can borrow one).
Looks very close to the revised versions for the firebirds (yours looks like it might have a little more tilt on it).
http://www.hawksthirdgenparts.com/pr...-Cooling).html
If you're running a TPI I recommend you switch back to a 195* thermostat. You need around that to go into closed loop (which improves gas mileage).
Old Jun 3, 2013 | 07:43 PM
Keoman's Avatar
Seems that closed loop is based on 3 variables, all of which would be met by the 170* thermostat.
https://www.thirdgen.org/open-loop-closed-loop
After some datalogging, the temp stays right around 170* above 40mph.
The extremely low needle just set off some false alarms in my head.
My gauge is high about 10* as best I can tell.
Thanks everyone for the info.
Old Jun 13, 2013 | 09:53 PM
fatalicshock's Avatar
Car: 87 Trans Am
hell ill trade you lol my car always runs hot lol i could use that XD
Old Jun 14, 2013 | 11:20 AM
Keoman's Avatar
Just took a 1500 mile road trip. 95*+ outside temps at 90-100mph.
Fans NEVER once came on to cool the engine. Absolutely solved my heating issues 100%. Fan only comes on if I am sitting still.
Went over a few nasty bumps and never scraped either.
Defiantly recommended!
Old Jun 14, 2013 | 12:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Closed loop should set in well before 190. My stock setting for coolant temp for closed loop enable was 104!
Old Jun 14, 2013 | 02:20 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I read that the fans don't come on over 35mph. Whether or not it's true, idk. I don't even need them at 25mph with my aluminum rad.
Old Jun 14, 2013 | 02:38 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My heated O2 sensor closed loop comes in alot earlier too, and my car runs around that middle point, so more or less 180* which is exactly where I want it.
I have a new GM airdam (stock 3rd gen one) and it works perfectly, runs a bit under 180 on the highway and never goes up, even when flooring it on the highway. Only when I am stopped after some "spirited driving" that it heats up to a bit over 180 and the dual fans turn on and bring it down to a bit below the 180 mark.
Old Jun 14, 2013 | 08:16 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
My car enters closed loop about the time I exit my apartment's parking lot. That's on a "cold start" early morning start. (Which lately has been 77°F/96% humidity ambient temps)
I'm up to 180° temperature (same as thermostat) within about 5 blocks.
I don't know how you guys can gauge if your radiator fans are on/off while driving the car. Unless you have a data logger going on your laptop that shows the ECM controlled fan, the fans are silent. At least they are on my car. The only time I hear them is after shutting the car off. You get a few seconds of sound from them winding down.
At 70 mph this time of year, I'm running about 180-185°. Figure 10° warmer with the A/C on.
Old Jun 15, 2013 | 12:59 AM
All my lights dim slightly and rpms drop for a split second when the fans kick on.
Old Aug 10, 2013 | 11:51 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 4th gen air dam... very efficient!
Picked up a 4th gen air dam for $10.00.
Installing tomorrow
Old Aug 13, 2013 | 09:36 PM
Keoman's Avatar
I don't think you'll be disappointed. I know I sure wasn't!
Old Aug 14, 2013 | 05:48 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
easy - i have indicator lights on my dash that tell me when they're on/off... and i have lit them both up recently when my t-stat stuck closed and i had to get towed home...
Old Aug 14, 2013 | 03:35 PM
Car: 89 IROC
I have 4th gen dual fans and this as well to help with the cooling.....
Old Aug 14, 2013 | 04:11 PM
Keoman's Avatar
Ooo that looks nice
Old Aug 14, 2013 | 04:25 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
That is a good looking radiator. What make is it?
Old Aug 14, 2013 | 05:09 PM
Jeffs82TA's Avatar
4th gen airdams really no better then your 3rd gen one. My 4th gen ran hot up until I put a new radiator in it. Generally it stayed up around 210 on freeway after new radiator it cooled like it did when it was new. This wasn't a V8 4th gen either.
Old Aug 15, 2013 | 08:56 PM
KaI_S's Avatar
Car: 88 Trans am
Thats true. It doesn't matter that you put 3 gen or 4 gen air dam. I replace my old broken one with a new 3 gen one. when i am driving local. it wont go past half until i let it idle for 15-20 mins.
The only things I did on my car is flush coolant, water pump, thermostat 180' & new air dam. Even with AC on i dont have problem of the heat.
Old Aug 15, 2013 | 09:53 PM
Keoman's Avatar
When you don't have one to begin with, a cheap readily available alternative is better.
Old Aug 15, 2013 | 10:27 PM
How many quarts/gallons/litres did u need to put in when you flushed your coolant? And did you use 50/50 mixture?
Old Aug 16, 2013 | 07:24 AM
KaI_S's Avatar
Car: 88 Trans am
As i remember, it should be 16 Quarts if the whole coolant system complete empty. I am running 30 antifreeze 70 water but going to flush it again and put 50/50 back in
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
cam-mike
Aug 24, 2015 07:23 AM
