How Cold is your r12 retrofit to 134a?
Old Jun 22, 2013 | 08:47 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Lets just keep it R12-R134... i know theres better refrigerants but GMAB....
Did a Evac and recharge few days ago... My systems as im sure all of ours holds 2.2lbs r12... and 134a doesnt take that much. so i guessed at 2lbs. I had while it was roughly 90*f... +/-3*
Min-62*F Steady in traffic, Max High
Min-50*F On Max High going down the interstate 2hrs steady 70-80mph
Accumulator temp was at 47*
Then Today, i Replaced the orifice tube to the Famous Ford Blue..
Same Temperature outside... on my way home tonite....
50-53* in traffic Max High
42-44* 20 minutes of mixed highway/city Driving.
Accumulator temp was at 37*f
8* may not be a huge difference....... But Im from Maine, Moved to NC a year ago. and i'll take the colder 8 Deg. It was def. worth it for me......
Is there any other smarter to use orifice tubes being used in our Thirdgen's??
Old Jun 23, 2013 | 01:17 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: How Cold is your r12 retrofit to 134a?
The deal with R134 is that it moves at a higher pressure so go offset that, I always suggest at some point swapping to a higher output electric fan to pull more heat out of the condensor-that faster the Freon moves through the system, the less time there is for heat dissipation.
Old Jun 26, 2013 | 07:54 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Or just switch to R-152a aka Diflorethane aka Air Duster. I have it in my 2012 Titan and it gets down to 37°F on the highway and runs 50 psi less head pressure than 134. My 97 Express has Duracool which is a propane based blend. It blows ice cubes as well and also runs much lower head pressures..
Old Jun 26, 2013 | 07:59 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
No amount of airflow mods really help R134a at idle, I tried many on my Express with little help to its performance. I sealed the fan shroud to the radiator and the radiator to the condenser with foam, added a HD fan clutch and a tow package cooling fan from a Tahoe. Still not satisfied I put a 16" 2,500 cfm electric fan between the radiator and mechanical fan on a custom mount. Best I could cool was about 48°F on a hot day at idle. Dropped in Duracool and instant 35-38° vent temps at idle with both fans on high.
Old Jun 30, 2013 | 10:43 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
8° is a huge difference! The blue orifice tube definitely looks to be worth the $5 cost.
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
scottmoyer
Sep 7, 2015 07:06 PM
