so i broke this today .. what is it? (pic)
Old Jul 30, 2013 | 08:22 PM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
Camaro 92 RS v6 3.1
was working on therm stat and got done with it. and started put 2 hoses back onto the throttle body and then must of pushed pulled wrong way and snap..
there is peice sticking out still that could grab probably get to it easier if could get this peice infront of it out of the way.
metal hose is stuck to something under alternator . does this piece come apart from this metal niche holding it in place?
from the heater control valve to under therm housing line is what im talking about. goes from lil rubber at hcv to metal then to some plastic piece going right under where thermostat is... <broke that part>
bahh. if could move this thing could probably get that piece that broke off better but seems weilded in almost lol.
did i screw the pooch on this one?
Old Jul 30, 2013 | 08:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: so i broke this today .. what is it? (pic)
You can thank gm for using cheap pot metal , I believe dorman has it in there help 800-401
acdelco 15-75224,
You will need to chisel it out out I have pounded in a cheap socket extension to remove it.
You can also cut down just a little ways with a hack saw blade to weaken it the chisel out the pieces. Be careful not to damage the threads on the manifold.
Old Jul 30, 2013 | 08:35 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You'll need one of these to remove it. You drive it in and unscrew whats left. You may also need a tap to clean the threads.
Old Jul 30, 2013 | 09:14 PM
TAmaniac's Avatar
Car: 85 Trans Am
Axle/Gears: 342
Yea, that tool sucks. Hardly ever works. It won't grab the soft metal. I take a small grinding bit and carefully grind one side and then the other side and it falls apart. I run a tap through it, install new fitting and good to go. Works every time.
Old Jul 30, 2013 | 09:23 PM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
ok so this is the new peice i need right?
ACDelco 15-75224 Heater Water Engine Inlet Nipple : Amazon.com : Automotive ACDelco 15-75224 Heater Water Engine Inlet Nipple : Amazon.com : Automotive
and then does this piece screw off that metal its still connected to?
Old Jul 30, 2013 | 09:31 PM
Engine: Lb9
Transmission: M20
Depress the ears on the plastic clip to release the nipple. Double check the p/n for application listing on the acdelco 15-75224.
http://parts-catalog.acdelco.com/cat...&parttype=4129
Old Jul 30, 2013 | 09:41 PM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
http://www.dormanproducts.com/p-1063...6%20189%203.1L
soo looks about same as amazon then right?
Old Jul 30, 2013 | 09:42 PM
Engine: Lb9
Transmission: M20
yup
http://www.ebay.com/itm/GENUINE-GM-AC-DELCO-HEATER-HOSE-CONNECTOR-GM-PART-88891735-/251307703200?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a831b3ba0&vxp=mtr
Old Jul 30, 2013 | 10:35 PM
TTOP350's Avatar
It works great, drive it in, spin it and it will normally clean the old krap out to the top of the threads, then, run the tap in to clean the rest of the old fitting out of the threads.
Old Aug 5, 2013 | 02:02 AM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Agree, tool rarely works, but can give it a try. I would get rid of the quick connec and replace with barb fitting and moulded 90 hose
Old Aug 16, 2013 | 03:31 AM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
Ok got new part on finally hooking everything back up an have new upper Rad hose by 11am. An can test it an everything cuz was working on replacing Therm stat. Ok so the old part that broke had a lil o ring in it do I need put this in the new part or no since new part didn't come with one? This is only thing unsure of
Old Aug 16, 2013 | 03:34 AM
Engine: Lb9
Transmission: M20
it should have came with a o-ring already installed in the fitting. I'm not a fan of reusing o-rings your just asking for a failure.
Old Aug 16, 2013 | 03:18 PM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
ok its all put together besides the alternator isnt connected cause broke the female plug.. thanks for helping with that about to buy one.. but i was wondering cause my coolant starts boiling back at around 210 215. when does my engine fan come on? i turned it off once started boiling back just incase. It sucked like thermostat opened early on.
but ya when does stock normal fan kick on or watever? i always seemed that it was around 220 or so as it seem to always run hot and boil back like always did
Old Aug 16, 2013 | 03:19 PM
Engine: Lb9
Transmission: M20
I think on the v6 its 226f, make sure you bleed the cooling system well.
Old Aug 16, 2013 | 03:20 PM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
thank you so much for help by the way omg just that the coolant is not leaking is a miracle lol. it started leaking out of metal that connected to the new broken part and i was soo pissed i and confused i was like **** all i can think is bang on it with a hammer lol... sure enough i banged it far enough in and it stoped leaking on me...
thank you so much i love my car i love 3rd gen and im so crazy but proud to have just gotten this far lol and my car still work your great friend for reall
Old Aug 16, 2013 | 05:02 PM
DXDoug's Avatar
Car: Camaro RS 1992
Engine: V6 3.1L
i bleed the cooling system until it starting boiling back out at me lol now i gotta refill all that shot out
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Amillionoh7
Sep 11, 2015 11:36 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
