Help me Choose a Radiator, Want to replace mine Your thoughts on type.
Subscribe
Dec 5, 2013 | 08:08 AM
Hi, I replaced the Radiator in my car about 15 years ago, I went with a stock replacement. The car is running hotter then I like these days and the Radiator is starting to look pretty nasty inside.
1. Should I go stock Replacement again? If so who and where make good ones for a good price?
2. How Many row do I want?
3. I think I may want to replace it with a Aluminum one, If I go this route who makes a nice one?
4. How Many row on a Aluminum one would I want?
5. Can I get a Aluminum one that bolts right up and use stock hoses and stock mounting hardware?
6. Best Prices on these items can be found where?
7 . Pros and Cons of Aluminum and Brass?
Car is in Sig Below. Thanks
Reply 0
Dec 7, 2013 | 12:02 PM
Re: Help me Choose a Radiator, Want to replace mine Your thoughts on type.
I have a Champion 2 row all aluminum in my 86 TA.
I have a Gm 350 crate engine in my car and this Champion unit works great. Comes up to temperature and pretty much stays at the thermostat temp.
http://www.ebay.com/itm/RADIATOR-CHA...b9672a&vxp=mtr
Also make a 3 row
http://www.ebay.com/itm/1982-1992-PO...d8e94d&vxp=mtr
I will warn you, they fit pretty much like the original, but the rubber mounting saddles will have to be trimmed down to about 1/4 their original thickness due to this rad being so much thicker.
Most of the new stock replacement rads I have seen are only 1 row aluminum core with plastic tanks. My car would borderline overheat on a warm day with a brand new stock type single row.
Reply 0
Dec 7, 2013 | 08:08 PM
Yeah I read the whole thread up top after I posted this, I am thinking of getting one of those Radiators. I just don't want to get it and it not like it, I need one that will keep my car cool.
Reply 0
Dec 7, 2013 | 08:42 PM
If your running a stock type rad now, the Champion will cool way better.
Reply 0
Jan 2, 2014 | 08:52 AM
Anyone know what size thread the Tranny Cooler ports are on the new style Champion Radiator? I would like to plug mine since I am running a 5 Speed.
Also Do the PS Pumps run a cooler on our cars?
Reply 0
Jan 2, 2014 | 09:07 AM
People I know who have the Champion love it. I got a similar one off ebay from Radiator Classic for less money... it's a two row, and it works very well for me. I only have a stock 305 TPI, so not sure if a more powerful car would need something more.
Reply 0
Jan 10, 2014 | 09:19 AM
I'm running a BeCool Aluminum radiator in my 84 T/A and love it. Bit on the expensive side though.
Reply 0
Jan 10, 2014 | 01:19 PM
According to the experts an aluminum radiator with two rows of 1 inch tubes is the best design. Adding purple ice (2 bottles) or watter wetter will drop your temps about 12-15 degrees. I like to use distilled water since this greatly lowers corrosion. I have a be-cool and and a taurus fan and I have never seen its equal and I have had up to five fans before and all kinds of wiring, shrouds and air deflectors. I live in Arkansas and it gets Africa hot here so we must have a very good cooling system. We usually have 30 days in triple digits in the summer time. Myron Cottrel, John Lingenfelter and many others like a 170 stat the best for a hot climate. Check my other post in the cooling section for the GM part number for one.
Reply 0
Jan 10, 2014 | 04:34 PM
I was up in the air over 2 or 3 row, I ended up with teh Three row, Of course I was told about two row after I ordered the three.
Reply 0
Subscribe
