Anyone try Or know about the Mishimoto Alumium Radiator?
Old Dec 6, 2013 | 08:25 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Anyone Try the Mishimoto Rads?
Price doesn't seem all that bad, Not as good as the Champion Ones but still better then some. I wonder how they fit and how they Perform, Anyone know?
http://www.mishimoto.com/chevrolet-c...tor-82-92.html
http://www.summitracing.com/parts/mi...t/model/camaro
Old Dec 6, 2013 | 08:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Anyone try Or know about the Mishimoto Alumium Radiator?
looks like its well constructed . Wow a lifetime warranty
Old Dec 6, 2013 | 08:41 PM
BLACK Z's Avatar
Car: 86 Z28
It does look nice, Just wondering if it fits well and how does it Perform, I may go with this one instead of the Champion, but Id like to here peoples thoughts.
Old Dec 6, 2013 | 10:02 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
The Project
Has a Mishimoto, maybe ask him if he has done a mock-up.
He's doing a great job on his rebuild!
Old Dec 7, 2013 | 12:08 PM
joshc's Avatar
Car: 1986 Trans Am
The only concern I have is the rad filler neck where the cap goes on. It does not appear to be welded on from the pics. If it is epoxied on, that is a potential failure point.
I would ask the company how that filler neck is secured before I ordered.
Old Dec 7, 2013 | 08:04 PM
BLACK Z's Avatar
Car: 86 Z28
I search his name and see if I can find him.
Old Dec 9, 2013 | 10:38 AM
Mishimoto's Avatar
Hey everyone, thought I'd jump in here to help clear up any questions about our products. This radiator is a direct-fit into the Camaro, and will not require any modification. It is also a 3 row core, with all-aluminum construction, and is fully TIG welded. This will allow for increased reliability and cooling efficiency.
To answer Joshc's question, yes our fill neck is welded onto the radiator. It is welded from the inside to give it a cleaner overall look.
As Tuned Performance pointed out, we do have a lifetime warranty on all of our products! This can save you from any headaches, since this will be the last radiator you will need to purchase for this car.
Please let me know if there are any other questions, as I would be happy to help!
Thanks,
Tyler
Old Dec 9, 2013 | 12:46 PM
BLACK Z's Avatar
Car: 86 Z28
Tyler Does it take a standard Rad cap if I need to replace it? The Sticky up top is about bolt in Rad and they are not always just a bolt in affair.
Mishimoto I sent you a PM also.
Old Dec 9, 2013 | 01:56 PM
Engine: Lb9
Transmission: M20
Thanks,
Tyler
I will be more than happy to take pics and try out a radiator for free
It really looks like a great value bang for the buck , count me down for one when I get my 383 done
Old Dec 10, 2013 | 11:55 AM
Mishimoto's Avatar
We have not confirmed fitment of the stock rad cap for this specific radiator, but it should fit. Though, if there are any issues with the radiator cap, it will be covered under our lifetime warranty, so you shouldn't have to worry.
Awesome! Let me know if you have any questions before placing an order!
Old Dec 10, 2013 | 01:32 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Here're some reviews I found. Sounds like a good deal.
http://radiator-review.com/mishimoto.html
Old Dec 10, 2013 | 06:42 PM
BLACK Z's Avatar
Car: 86 Z28
None of the Reviews seem to be about our cars. Do to the Champion Radiator Sticky above I am leaning toward one of there Rads, I have spoken with there Support staff and they were very Helpful. I just don't know if I am willing to take the chance on this Rad since it is over a $100.00 more. If the Price was closer maybe I would.
Old Dec 10, 2013 | 07:16 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Ditto
Old Dec 10, 2013 | 07:17 PM
Engine: Lb9
Transmission: M20
IMO , The warranty is worth the extra $100. The Champion requires the top and bottom rubber mounts to be cut down so the radiator hold down can be reinstalled.
http://www.mishimoto.com/warranty-info.html
http://www.championcooling.com/products/warranty/
Old Dec 12, 2013 | 11:16 AM
Mishimoto's Avatar
Originally Posted by 1991sleeper
Ditto
This radiator is a direct-fit with no modification required, and it comes with a lifetime warranty. With a lifetime warranty on our products, it is safe to assume that they will be of the highest quality, but it is still nice to have the peace of mind that comes with a lifetime warranty.
Thanks,
Tyler
Old Dec 14, 2013 | 08:48 AM
joshc's Avatar
Car: 1986 Trans Am
Thanks for replying Tyler, with the welded neck, it looks like a top notch rad!
Hopefully someone tries one and lets us know how it fits.
I put a Champion in my TA last year and have been happy with it, but did have to modify the rubber mount saddles to get it to fit. If the Mishimoto fits without mods, it sounds like a good deal.
Old Dec 19, 2013 | 08:47 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
I am looking at this radiator as a replacement for my oem (and broken) radiator.
I have several questions though. What is the tube diameter on the Mishimoto radiator? Champions equivalent 3 core only has .63 inch diameter tubes, the Superior Radiator (2 core) has 1 inch tubes, as well as Summits own Radiator (2 core). And does the stock single electric fan and shroud work with the Mishimoto radiator? Superior Radiator says OEM fans and shrouds bolt right on.
Old Dec 29, 2013 | 11:43 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Originally Posted by t-top havoc
The Project
Thanks for the kind words.
Mishimoto rad is a quality piece. Mock up was spot on the will fit my 4th gen dual fans perfectly.
Here is my Mishimoto thread with pics
https://www.thirdgen.org/forums/afte...-alum-rad.html
Build will continue when the snow here melts
Old Jan 2, 2014 | 07:49 AM
REBSTA's Avatar
Tyler, I am looking at several combinations and the only shortfall on the Mish is the need of high flow fans. looking at the Mish website I do not find a combo with the rad that flows high over 3000 cfm. Maybe I am missing something. Do agree all with the fit and finish of the product..just need a complete combo for show and race car combo. I'll be pushing 750hp with supercharger. I have spent numerous hours on many forums and reading way too many articles..so I'm tired of reading and ready to pull the trigger..
I bought the Flexlit setup but realized when I got it, it doesn't not have built in trans cooler.
Old Jan 15, 2014 | 02:04 PM
Mishimoto's Avatar
It looks like each tube is approximately .60 inch in diameter. Yes, OEM fans will mount directly onto the radiator.
Thanks!
Rebsta, thanks for the post. Unfortunately, we do not offer a single fan set-up that has a CFM rating of 3000 or more. The core size looks like it would be able to house two 12" slim fans. Two 12" slim Mishimoto fans has a CFM rating 2300.
http://www.mishimoto.com/mishimoto-s...or-fan-12.html
Thanks,
-Pat
Old Jan 16, 2014 | 04:35 PM
kennyjames's Avatar
The idea of upgrading the radiator has crossed my mind. I am guessing the price of the radiator would be in the ballpark of three to four hundred USD based on the prices of their other products.
Mishimoto radiators are very nice and offer a lifetime warranty. It would be great if they made a radiator that was a direct replacement vs trying to fit up one of their universal radiators. The claim in performance for Mishimoto's other products is to provide up to 25 to 30 percent better cooling than stock.
I would be interested depending on the timing of the release of the product and price.
Old Aug 28, 2015 | 07:15 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Thanks,
Tyler
What's the tube size?
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
