AC leak through low pressure port.
Old May 26, 2014 | 08:49 PM
Stalker7d7's Avatar
Car: '83 Camaro Berlinetta
Engine: 2.8L v6 (LC1)
Transmission: A3
I can fill it fine, but when taking the hose off it leaks rapidly. I can put the cap on and it stops, or almost stops the leak, but it leaks slowly over time.
I just replaced the shrader valve earlier today, and the same problem is there.
Did I not get the valve tight enough?
Old May 26, 2014 | 10:29 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: AC leak through low pressure port.
It could be not tight enough, but I doubt it (that would be hard to do unintentionally). I've had other cars where I had to replace the part that the low side valve is part of (line, accumulator, etc.) or it could be the wrong valve. Did you get a "universal" valve repair kit or did you buy a unique/specific part to fit your application?
Old May 26, 2014 | 10:55 PM
Stalker7d7's Avatar
Transmission: A3
Universal kit.
My car was converted to r134 by the previous owner. I got the universal kit for it at autozone I think... The piece looked the same as the one I took out, except it didn't have a bent pin...
Old May 26, 2014 | 11:15 PM
Lurbie's Avatar
Car: 89 Camaro
Universal kit.
OK, so did you just replace the schrader valve in the conversion connection? Or did you install a new conversion connector on the original R12 fitting? My thought is if you just replaced the valve and not the conversion fitting, maybe you can get that and screw it on.
Old May 26, 2014 | 11:27 PM
Stalker7d7's Avatar
Transmission: A3
Yeah, just the valve. Perhaps I'll see about the fitting.
Old Jun 2, 2014 | 11:05 PM
Stalker7d7's Avatar
Transmission: A3
New fittings did the trick. Thanks for the hep Lurbie.
Old Jun 3, 2014 | 08:46 PM
Lurbie's Avatar
Car: 89 Camaro
Old Sep 15, 2014 | 09:59 PM
92GTA's Avatar
I had this problem recently and it was with a GM AC Delco brand new receiver/dryer from GMpartsdirect.com
Even though I doubled check the tightness of both valves with the proper tool, the low side was still defective. ****ing hella pissed me off because it wasted the last of my R-406a over the next 2 weeks
I bought another receiver/dryer and 3 cans of legit R-12 from eBay. I'm going to remove all non R-12 everything, new o-rings, new orifice tube, new AC compressor and mineral oil, not just a reman compressor this time. Then I'm going to stick with R-12. I was really disappointed when I couldn't find anymore R-406a anyway anymore!
jklein337
Sep 19, 2018 06:23 PM
TheExaminer
Aug 26, 2015 04:59 PM
dcbsracing007
Aug 18, 2015 07:24 AM
wayshegoes
Aug 17, 2015 12:00 PM
jackhammer
Aug 15, 2015 10:04 PM
