STAYS AT 160 DEGREES?
Old Jul 13, 2014 | 05:03 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
Hi all! I've noticed lately that the temperature gage in my 91 TA with the 350 warms up to 160 degrees and stays there. I replaced the thermostat last year and just replaced it again because of this but it still stays at 160. I have been using a 180 degree thermostat. Is this normal? If not, could it be the temp sensor or the gage? It has been setting a code 44 for lean condition too but don't think that it is related? Thanx!
Old Jul 15, 2014 | 12:33 PM
THCARGUY's Avatar
Engine: 350 in both
Re: STAYS AT 160 DEGREES?
One more thing. When I say that it is stays at 160, that is just what it shows on the temp gage inside the car. Not sure what the temp actually is.
Old Jul 15, 2014 | 03:13 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Are your fans in the factory set up or wired to stay on all the time?
Rent/borrow an IR thermostat and check the temp at the top of the radiator.
Our gauges are notoriously off. My temp gauge above the hash between the 220* and redl line when my fan turns on (Fan switch 215* fan switch) so I'm at least 20-30* high on my reading.
Old Jul 15, 2014 | 10:55 PM
THCARGUY's Avatar
Engine: 350 in both
My fans are still setup from the factory. I have owned the car for nearly 20 years now and I was thinking that the temp gage usually varies more, moving upwards towards the 220 mark at times. Right now it just heats up to the 160 mark and stays there. I am thinking about replacing the temp sensor just for grins since it appears to be the original one.
Old Jul 16, 2014 | 09:47 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
if its like the truck engines there are two separate sensors, one by the thermostat for the ecu and one by the pass side head for the gauge. if its lean i would guess the engine really is 160 and either the pcm is seeing the wrong temp and turning the fans on early or there is a stuck relay making it be on all the time.
Old Jul 16, 2014 | 04:47 PM
THCARGUY's Avatar
Engine: 350 in both
I really hadn't thought about the fans being on too long. I will check that out. So if the car is running too cool then the computer might lean the fuel mixture?
Old Jul 17, 2014 | 04:24 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If the ECM thinks the engine is cool it would richen the mixture.
Think in terms of a carburetor. Cold engine = choke only partially open = rich mixture.
Old Jul 17, 2014 | 08:46 PM
THCARGUY's Avatar
Engine: 350 in both
That makes sense. Darn! I was hoping to maybe fix two problems with one fix. I am also at this time getting a code 44 (lean mixture) that I have posted a thread for in "Tech/Engine".
I just replaced the o2 sensor but I really don't think that is my lean problem. I still haven't had a chance to check out the fan suggestion yet. I sure appeciate everyones input!
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
lewandom
Oct 1, 2015 08:15 AM
