1989 Camaro overheating
I have a 1989 irocz with a brand new chevy 350 crate 260hp/350tq motor in it. It's equipped with a 17 in engine driven fan with stock fan shroud, a 16 in electric pusher fan on opposite side of radiator, a 185 thermostat, a brand new stock radiator, brand new upper and lower radiator hoses, proform 650cfm carb, and the air dam is intact. There car is running at 220 degree under normal driving conditions. I have tried a 160 thermo and a 195 thermo and both of those caused it to get even hotter. Anyone have any idea on the cause for the mor running so hot
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: 1989 Camaro overheating
my opinion is the stat, its open all the time and doesn't let the water cool believe it or not.
Car: 91 ws6
Engine: Carb'd 334 stroker
Tried removing the mech fan, and switching your electric one to a puller mounted on the other side? I'm running like that with a 180, mangled dam and a crappy radiator in ball-soup-humid Kansas and I'm at 170-200. 210 on a really hot day
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
220* is normal operating temp for these cars. As long as it doesn't get any hotter than that, you should be fine. If it's not boiling over, you're not overheating. Also, realize that your gauge my be off. Double check the temps with an IR thermostat. My car has a 210* fan. Using that as a guide, my car is easily reading 230* when it kicks on meaning i'm reading 15-20* hotter than it actually is.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah i just checked mine. gauge reads 220 thermo housing reads 175-180 with a infrared gun
Car: 1983 Z28
Engine: 385 Fastburn
Do you have the correct water pump on the engine? (i.e. one that is for the belt setup you have?)
I had a serpentine water pump on my engine (with a V-belt setup) and experienced very similar issues to what you're describing. Swapped it out for the right one and was good to go.
Only time I ever touch 200 is in stop and go traffic in 95+ degree weather.
Car: 88GTA
Engine: 5.7TPI
Good one Dixie.......never heard it called that! I could have used that down here
in Bama this past weekend!
Car: 1983 Z28
Ok, was the 305 pump you purchased also for a serpentine setup? just verifying.
Car: 1983 Z28
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
